Jump to content
Electronics-Lab.com Community
Need help with really simple thing!
hyaku_
Hello!
I need a little help! I'm really new to electronics! Please take a look at this picture:
That C1! How is it called? when I connect my led with C1 and battery, it only flashes once and then only flashes second time, if I disconnect and connect wires again! What is the point of this C1? Thank you!
Link to comment
Share on other sites
Hi hyaku_
You do realize that you have a NPN(Q1) and PNP(Q2) transistors?. C1 is an electrolytic capacitor polarised,(+ and -).
D1 and your LED are also polarised. If you have connected one of your transistors incorrectly it may be damaged.
More than likely you have made a connection error ;).
I hope this helps :).
Link to comment
Guest Yevgenip
C1 is a component called a capacitor(cap for short). The simplest capacitor is non-polorized and consists basicly of two metal plates that are seperated by a thin layer of non-conducting material. It is capable of storing energy and releasing it. It's capacitance is measured with Farads. One Farad is the capacitance of such a capacitor that a voltage of one volt over it will create a charge of one Colon in it. That is a lot so we use mF, uF, nF and pF.
An electrolytic capacitor is similar, only it is polorized.
Hope I Helped! ;D
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
