Jump to content
Electronics-Lab.com Community
  • 4 months later...
  • Replies 60
  • Created
  • Last Reply
Top Posters In This Topic
Posted
Well i have all the transistors , diode and i felt lucky in getting the exact Darlington pair both are from texas instruments and are BDW84D and BDW83D respectively
so now how will it behave , how much watt  ???
Posted
As I said at the beginning of this thread, a 28VAC transformer won't make 40VDC at its full loading, but if this circuit has positive and negative 40V then the amp will probably provide 85W into 8 ohms or 140W into 4 ohms.
Posted
I have a Transformer capable of delevering 8A @  2 x 28V . and one more thing , i could not found P600B , can i use a simple 1000V @ 6A diodes that i can find , i don't have the exact number , but i will if i buy it
Posted
ok then i am preparing to add something else , temprature meter , fan , and a Power meter that shows the actual wattage, for power measurment i will be using  a ADC to measure voltage and current and then when it is binary form , digitaly multiply them using logic gates , and then convert the binary power output to 7 segment using a BCD to 7 segment decoder . how is the idea ..
Posted
Why make a complicated power meter? The power changes in less than a milli-second so a 7-segment display will be a blur.
You hear loudness, not power. Just make an LM3915 LED bar-graph sound level meter or voltmeter. Have a peak-detect circuit to hold readings for about 50milli-seconds so they are visible.
  • 3 months later...
  • 2 months later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
