Jump to content
Electronics-Lab.com Community
lm339 comparator
jpp412
I'm trying to understand the function of the 339.  I have read all of the datasheets (which don't help very much as far as basic understanding) and think that the basic idea is to output high when the + input is > the - input and a low otherwise.  Is this the correct basic idea?
Beyond that - when I look at the example datasheets which include application examples - I find that most of the examples elude me in terms of what they will do.
Any help or pointers to resources that I could study would be much appreciated.
Thanks in advance.
Joe
Link to comment
Share on other sites
Hi Joe,
You almost understand the operation of an LM339.
Since the output is only the collector of an NPN transistor, the output becomes open-circuit (and is pulled high by an external resistor) when its + input is more positive than its - input. When its - input is more positive than its + input then the output transistor conducts and pulls any voltage provided by an external pull-up resistor to ground.
The datasheet applications show that this comparator is just a switch to ground that is controlled by the very accurate voltage match of its inputs.  ;D
Link to comment
A comparator litterly amplifies the logic into oblivian. No, not really oblivian for the fact that the unknown zone exists. So basically you have a modest type amplifier I think. I still think these things have higher gain. I know that the output is always good provided the input. It's funny but they actually have a gain of 1. But in reality, and this is the point I am trying to make, the voltage curve rises to it's uppermost voltage very quickly because the gain is high. So no it is not accurate to potray the voltage as not doing enough to make the transition. It does quite a bit, but the voltage will always charge with the capacitor. So although the voltage flies immediately, the RC time constant will hold onto the voltage keeping it slewed.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
