Jump to content
Electronics-Lab.com Community
Posted
All,
Have you ever heard about a charger charging 39 NiMH cell battery pack?
Looks like usual charger charge up to 24 cells max?
If this kind of charger is not available at all, is there a way I can modify an existing charger to do the job? or can I just add a voltage divider to the battery and charge it by using a normal charger?
Cheers,
Batteng
Guest Alun
Posted
With the normal 1.2V per cell you'd get 46.8V.
What capacity are these cells?
Posted
My AA size Ni-MH cells measure 1.4V after charging slowly all night. Therefore 39 of them would require a charger output voltage of at least 54.6V plus more volts for the current limiter. A charger for a 48V lead-acid battery would probably have enough volts but the current would be excessive. A current-source circuit would need to be added to reduce the current.
Guest Alun
Posted
Constant current then float at 54.6V would be perfect, but we need to know the capacity to calculate the current.
Posted
All,
These cells are rated to 9Ah. I expect to fast charge them at C/4 or C/5 (2 to 2.5 A).
The total battery voltage is 39*1.2=46.8V nominal and 36*1.65=59.4V max (fully charged).
Hope it helps.
Cheers,
Batteng
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
