Jump to content
Electronics-Lab.com Community
An Ultrasonic Cleaner--Schematic
Coppied from:
http://repairfaq.ece.drexel.edu/sam/samschem.htm#schahv
Ultrasonic Cleaner
Ultrasonic cleaning is a means of removing dirt and surface contamination from intricate and/or delicate parts using powerful high frequency sound waves in a liquid (water/detergent/solvent) bath.
An ultrasonic cleaner contains a power oscillator driving a large piezoelectric transducer under the cleaning tank. Depending on capacity, these can be quite massive.
A typical circuit is shown below. This is from a Branson Model 41-4000 which is typical of a small consumer grade unit. The H and N are Hot and Neutral of the 115 VAC line. WARNING: Line connected input. Use isolation transformer for safety when troubleshooting.
Link to comment
Share on other sites
Guest Alun
So far so good hotwaterwizard, how are you drawing this?
Are you using a special program or are you using paint and putting some pre-drawn symbols togeather?
Link to comment
  • 2 weeks later...
Guest Alun
You've still forgotten to put the kHz in, here I've done it for you.  ;DI can't see any other errors but don't take my word for it come back in a weeks time and see  ;D
Link to comment
  • 3 months later...
  • 1 month later...
  • admin featured and unfeatured this topic
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
