prateeksikka Posted June 11, 2005 Author Report Posted June 11, 2005 hi audioguru!where can i connect this neon bulb and high value resistor.is there any method to measure the polarity using my lightening conductor.hey i guess i can measure the direction or current flow in the lightening current of my building but how?through an electrolytic cap? ;D Quote
kid_kv Posted June 13, 2005 Report Posted June 13, 2005 HI, ALLHear is a link that might help out http://www.srh.weather.gov/srh/jetstream/lightning/positive.htmthis high voltage site is whear it came from and was posted in the high voltage stuff by Audioguru http://205.243.100.155/frames/longarc.htm#Disconnect ther is a pic of a lightening strike down the page :osteven Quote
ante Posted June 13, 2005 Report Posted June 13, 2005 Hi Steven,Thanks for the whether link interesting reading and fantastic pictures, this confirms that there are both positive and negative lightning. Scary thing “300,000 amperes and one billion volts!” :o :o for how long period would you need this to fully charge a car battery? ;D Quote
audioguru Posted June 13, 2005 Report Posted June 13, 2005 I heard the thunder from positive lighning that zapped a kid on his bike near my home. He is very lucky to still be alive but is badly burned. It was sunny and the storm was far away. :'(A car battery and everything near it would be vapourized with 300,000A and a billion volts! ;D Quote
prateeksikka Posted June 13, 2005 Author Report Posted June 13, 2005 first link sent by steven clears that lower cloud is -ve and ground is +ve.so how come -ve lightening? ??? ??? Quote
kid_kv Posted June 14, 2005 Report Posted June 14, 2005 HI, prateeksikkathis is the 1st link on the page and might help out http://plaza.ufl.edu/rakov/ICLP2000/positive1.16.pdf ;DTo out run a lightening bolt you need to run at 60000 miles a second :oI have been trying to get a pic of a lightening bolt but they are toooooooo faststeven Quote
ante Posted June 14, 2005 Report Posted June 14, 2005 Hi Steven,If you try to take pictures of a thunderstorm at night it’s easier, just let the shutter stay open and you can get several lightning bolts on the same pic. That is if your camera allows you to keep the shutter open continuously or for a longer fixed time interval sometimes 4 or 8 sec or even longer. 8) Audioguru, No of curse you can’t let all of that energy run straight into the accumulator! :D You have to catch it first in a capacitor and then feed it through a resistor into the battery nice and easy! ;D What size of cap (uF) do you figure it would take to store the energy from a lightning bolt? 8) Quote
f4cepl4nt Posted June 29, 2005 Report Posted June 29, 2005 Ok, I'm not sure if anyone said this yet, but here is how part of lightning works:Whichever one is negative (the clouds or the ground, not quite sure) induces the opposite charge on the other thing. If that makes sense. Basically if the clouds are heavily negatively charged, when they pass over the earth they induce a strong positive charge on the surface. That makes the negatively charged ions in the clouds want to travel towards the earth. Then, once enough of those ions have accumulated, they go ahead and do that. Now as i said, it might be the other way around, I'm not quite sure, but this should give you a pretty good idea of how it works.The only thing i never really looked at is HOW the charges get so great in the clouds/ground which then induce the charge on the other thing. Quote
Codyhtml Posted June 30, 2005 Report Posted June 30, 2005 for the cap size i'm thinking somthing around 1,000,000,000,000,000,000,000,000uf and a very hi voltage cap too what would that be like the size of my house ;D or bigger :)EDIT the cap size would probably be 1,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000 Quote
ante Posted July 8, 2005 Report Posted July 8, 2005 Yea, that agrees with my calculations too! ;D Quote
