Jump to content
Electronics-Lab.com Community
LIGHTENING STRIKES
i think it is somthing to do about when the clouds get enough water vapor to rain they also have built up + (i think ) charge and the earth is -(i think) so all it is is HUGE arcing of the earth and i've heard that if there was wire longenough to run to one of the sphears in the atmosphere you could short out the earth and the weather would FREAK out :) but that is like 40mi in the sky and so much current would try to flow that it would probably burn the wire up before there was too much damage done :)
Link to comment
Share on other sites
Prateek,
Thunderstorms are formed when warm air rises quickly from Earth into the sky. As the warm air cools, it forms rain clouds (cumulonimbus). As the warm air continues to rise and cool inside the clouds, it drops water and ice. Lightning is caused by electricity moving in between clouds or between the clouds and the ground. The electricity is formed when the ice and water particles move around rapidly inside the clouds. As the particles move they become oppositely charged and they separate. The positively charged particles go to the top of the cloud and the negatively charged particles sit along the bottom of the cloud. The negative particles along the cloud bottoms grow large and are attracted to the positive charges on the ground. When the "attraction" between the different charges becomes strong enough, electricity flows from the cloud to the ground. This flow of electricity is a lightning strike.
Hope that clears it up for you.
Just as interesting is what makes the thunder: Since the Lightning lasts only a fraction of a second, but it is filled with energy, it is very hot. (It can reach temperatures that are much hotter than the sun). The heat of the lightning is what actually causes the thunder. As the hot electrical charge passes through the air, it rapidly heats up the air. The heated air expands very quickly and makes the loud noise called thunder.
MP
Link to comment
Nicely explained MP :D.
I'm no expert on the subject That's for sure, except for having the pleasure to witness countless storms here in oz 8) ;D, with spectacular lightning shows :o, anyway to the point I have been led to believe that lightning travels from the ground upwards, and I have heard this being stated many times.  you seem to be very knowledgeable on the subject MP, I would appreciate your thoughts on this ;).
Link to comment
anyway dazza!
u can assume anything whether it flows from clouds to ground or ground to clouds,
+ve in one case -ve in other.
So fast moving air separates the vapours in the clouds and makes them oppositely charged this induces opposide charge on earth(i mean opposite to charge on lower cloud) so charge moves to have neutralization.OK EVERYBODY? ;D ;D
Link to comment
no ante!
i dont mean that it is AC.
I mean to say that  u may consider any one of them (the cloud or the ground)
as +ve or -ve ultimately it is the flow of charge which neutralizes the 2.
if we assume opposite, the direction of current is reversed.Now whether +ve neutralizes the -ve or the -ve neutralizes +ve what difference does it make?
nothing. ;D
Link to comment
Hi Dazza,
Current always flows from a negative potential to a positive potential. Since the flow is determined by the positive and negative charges, it is flowing to the ground. (Negative particles along the cloud bottoms attracted to the positive charges on the ground.)
MP
Link to comment
Hi MP,
That’s correct, from negative to positive because the electrons flow in this direction. British car manufacturers knew this back in the sixties so they connected positive to the chassis (ground). I installed a stereo system in a friends Ford Cortina once and it was some extra work I might add. To be honest this was not wrong thinking just different thinking! ;D
Link to comment
  • 2 weeks later...
The radio reception was not very good, only the strongest stations worked acceptable. Some time later he found a kind of converter or filter for the antenna wire which made it possible to ground the antenna in the car body to get a good ground plane. I never saw this gizmo so I don’t know what was in it but it worked perfectly. I still wonder how it was solved (changing the polarity of the antenna)? Maybe it’s very simple to solve, it was not expensive. ;D
Link to comment
Hi prateek,
You will need a high voltage probe for your multimeter and I recommend rubber gloves! ;D
I think the polarity of the clouds towards ground (earth) must be considered as a dual power supply. Some are on positive side and others are on the negative side of earth potential. But that’s me thinking and I might be wrong!
Do we have any meteorologist in our community?
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
