Jump to content
Electronics-Lab.com Community
Posted
Hi source
I don’t understand what you mean “to work a Video head” and “Coils how to take voltage to the another side”. At least I know what a video head is! Can you try to be more specific? 8)
Posted
Hi source,
I am not sure about this, looks like some special application for a VCR head!
Are you trying to run this as a separate motor for a project?
Sorry, not much help !
Posted
I have an experiment with coils (I manage to this) You have to give a frequency to the coils (but not 50 Hz, it depends on the revolution) RPM/60 = frequency
But I dont know the RPM (How can I determine the revolution)
and I dont know how can I produce the frequency (with a signalgenerator, I think) (with ne555 IC)
Posted
Hi Ante,
I think Source shows the motor's slip ring contacts that connected to the spinning head. I think he wants to mount a circuit on the other side and needs a way to connect the circuit's power supply to the slip rings.
Are the contacts for the slip rings in the small ribbon cable shown? ???
Looking at the discolouration on the motor's shaft, it ran out of lube in its bearing. :(
The slip rings look bad too. :( ;D
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
