Um...Me123 Posted March 6, 2006 Report Posted March 6, 2006 I want to make a sensor that is wires to the sheet metal of a car body that when touched can activate something such as a 555 or a piezo (to be determined later).How do touch lamps work?Can I apply this to a car body somehow?Any ideas?I don't want an alarm system to go off or anything but just a little beep or something to warn people my car is "smart" and not to be messed with. Quote
ECET0purdue Posted March 7, 2006 Report Posted March 7, 2006 Connect it to your coil on the motor...... Quote
Um...Me123 Posted March 7, 2006 Author Report Posted March 7, 2006 How large of an area can a touch lamp sensor control? Quote
audioguru Posted March 7, 2006 Report Posted March 7, 2006 Hi Um,Your idea of having the entire car as a touch sensor has problems:1) Most touch sensors detect the effect of the 100pF of a human on a high frequency oscillator. The oscillator and the human are referenced to EARTH. So your circuit will need to have a ground strap under the car.2) Most touch sensors use a tiny touch plate so that the small 100pF to EARTH of a human has an effect. If the entire car is the touch plate then it will already have a big effect to EARTH and the addition of the small capacitance of a human will be neglegible. Quote
Um...Me123 Posted March 8, 2006 Author Report Posted March 8, 2006 Note: I'm completely ignoring the speaker/led portion of the circuit.I just been looking around at different sensors and I found these two circuits. Quote
audioguru Posted March 8, 2006 Report Posted March 8, 2006 The circuits are exactly the same when you remove the short of the sensor plate to the battery in the 1st one.It won't work if you get close to the sensor plate. It works when the resistance of your body completes a connection from the sensor plate to the negative battery terminal. Quote
Um...Me123 Posted March 8, 2006 Author Report Posted March 8, 2006 So will the first one work at all with that short in there?Both the pages that had these, which were published (to the web) in different years, said if you got close (not touch) it would work. Hmmmm? They both are for connecting the circuit to a metal object such as a doorknob. Quote
audioguru Posted March 9, 2006 Report Posted March 9, 2006 So will the first one work at all with that short in there?Of course it won't work with its input shorted to the positive supply.Both the pages that had these, which were published (to the web) in different years, said if you got close (not touch) it would work. Quote
steven Posted April 20, 2006 Report Posted April 20, 2006 :)theres a circuit in electronics lab somewhere called an everything that moves alarm. and it has a metal sensor plate , can you use a whole car as the sensor plate , so it goes off when you get near it Quote
