audioguru Posted August 21, 2006 Report Posted August 21, 2006 Use 2 Mosfets and a 200W transformer for a 200W inverter.The IRF540 Mosfet is cheap and common. It can conduct a peak current of 33A. Therefore its RMS max current is 23A. It has a max on-resistance of 44 milliohms which produces a voltage drop of 1.0V. The 10V-0-10V transformer gets a loss of 1V in the Mosfets so the circuit's voltage is 9V RMS times the 23A= 207W.Modern Mosfets with a lower on-resistance and a more powerful transformer can make a more powerful inverter. Quote
kachew Posted August 21, 2006 Report Posted August 21, 2006 dear audioguru,thanks again for the help and giving so much information to me.. ;D ;D Quote
Morro Posted August 22, 2006 Report Posted August 22, 2006 hi Audioguru and kachew,is the inverter circuit works?? have anyone tried before?? what is the usage of the 0.01/5w parallel resistor used for?? and the diode 1N5408??? thanks for reply Quote
audioguru Posted August 22, 2006 Report Posted August 22, 2006 Hi Morro,I don't think the 0.01 ohm resistors are required.The diodes are also not needed because power Mosfets have the diode built-in them. Quote
Morro Posted August 22, 2006 Report Posted August 22, 2006 hi audioguru,the diodes and the resistor not used to absorb voltage spikes?thanks for reply.. ;D Quote
audioguru Posted August 22, 2006 Report Posted August 22, 2006 Hi Morro,Four 0.01 ohm resistors in parallel like that is 0.0025 ohms, which is the same as a short piece of wire. It does nothing in the circuit.All power Mosfets have the diode inside as a part of how they are made. In fact, it is a high-power zener diode which protects the Mosfet from d-s voltage spikes. Quote
Morro Posted August 26, 2006 Report Posted August 26, 2006 dear audioguru,the oscillator CD 4047 and the CD4001 really can make it to become modified sine wave? i think in order to make modified sine wave i think we should change from NOR and inside the cd 4001 to XOR gate?thanks for your reply... :o :o Quote
audioguru Posted August 26, 2006 Report Posted August 26, 2006 the oscillator CD 4047 and the CD4001 really can make it to become modified sine wave? i think in order to make modified sine wave i think we should change from NOR and inside the cd 4001 to XOR gate?I think NAND gates or NOR gates will work. I didn't look at XOR.Here are waveforms with NAND gates. NOR would make similar waveforms except the inputs go low to produce a high output. Quote
Morro Posted August 26, 2006 Report Posted August 26, 2006 hi audioguru,how about the efficiency of thr circuit? it seems having efficiency only 50%, if so is there any method to improve the output so that having more steps? thanks for reply... ;D ;D Quote
audioguru Posted August 26, 2006 Report Posted August 26, 2006 The efficiency is very high, maybe 95% with good Mosfets:1) One Mosfet is on.2) Both Mosfets are off.3) The 2nd Mosfet is on.4) Both Mosfets are off.Repeat.When a Mosfet is on then it has a very low voltage across it so its wasted power is low.When both Mosfets are off then no power is wasted. Quote
Morro Posted August 27, 2006 Report Posted August 27, 2006 hi audioguru,MOV is used to protect circuits against excessive transient voltages and how about the output overloading protection?? as i know many inverter nowadays have that function ::) ::) Quote
audioguru Posted August 27, 2006 Report Posted August 27, 2006 MOVs work very well to clamp voltage transients. But only until they burn out. This simple circuit uses a fuse for overload protection. I don't know if the transistors will survive long enough for the fuse to blow. Quote
Morro Posted September 3, 2006 Report Posted September 3, 2006 hi audioguru, i see the datasheet of the mosfet of IRF540, if the ic CD4047 produces output of 5V the the Vds would be 7.5A from the mosfet. ??? ??? i still cant think of how to supply the 10V to the transformer? is it from the +5 and -5V from the IC??? how do the mosfet do its job??? thanks for your reply :-[ Quote
audioguru Posted September 3, 2006 Report Posted September 3, 2006 Hi Morro,The IRF540 Mosfet is pretty old so has a fairly high on-resistance compared to newer Mosfets. Therefore they will get hot in a powerful inverter.The CD4047 is Cmos with a supply voltage rating up to 18V. It doesn't need a supply of only 5V like old TTL logic chips, it works fine from 12V and can directly drive 12V to the gates of the Mosfets in a square-wave inverter so that they turn on as hard as they can.If you are talking about a modified sine-wave inverter then the CD4001 logic gates are also Cmos and can have a 12V supply to directly drive the gates of the Mosfets with 12V.The center-tap of the transformer is connected to +12V. Then the Mosfets ground one side alternately. There is not a -5V. Quote
Morro Posted September 3, 2006 Report Posted September 3, 2006 hi audioguru, but i saw the thread here stated that the modified sinewave inverter by kachew is 10V-0-10V...can it be feed in the 12V from the IC??? and it should be having loses of 1V from the mosfet in parallel... :-\ :-\thanks for your reply Quote
audioguru Posted September 3, 2006 Report Posted September 3, 2006 Hi Morro,The peak voltage of a sine-wave is 1.414 times its RMS value. Its RMS value is the same as the peak voltage of a square-wave. So the peak voltage of a modified sine-wave inverter must be higher than if it is a square-wave inverter.The fully charged car battery is 13.8V and the Mosfets have a loss of about 1V. Therefore the remaining 12.8V into the 10V winding of a transformer produces close to the correct peak voltage for a sine-wave. Quote
kachew Posted September 6, 2006 Report Posted September 6, 2006 hi audioguru,i think there is some problem due to the circuit....i think the CD4047 and CD4001 can be act as the control circuit for the swithing circuit which must consist of four mosfet in order to get the modified sine wave?? in the 1st cycle the signal from the control circuit will go trough the 1st then to the 1st winding of the transformer and back to 4th mosfet to get the +12V at the transformer and get the positive pulse at the output of the transfomer. in the 2nd cycle, the signal from the control signal again pass through the 2nd and 3rd mosfet again to get the negative pulse at the output of the transformer....pls comment and thanks for your reply Quote
audioguru Posted September 6, 2006 Report Posted September 6, 2006 Hi Kachew,The center-tap on the transformer is supposed to be used to power the Mosfets while they conduct on each side alternately. Then each end of the transformer's winding is supposed to be driven by the drain of a Mosfet for the full battery voltage to be applied to the half of the winding.You are using the Mosfets as followers since the transformer is at their sources. So when the logic drives a Mosfet's gate to +12V then the source follows to only about +2V. But then the other end of the winding isn't connected to anything (a turned-off Mosfet) so no current flows in the transformer.Let the 1st side conduct on its pulse, then a pause while nothing conducts, then the other side conducts, then another pause when nothing conducts. Quote
kachew Posted September 6, 2006 Report Posted September 6, 2006 hi audioguru, then what u means is the mosfet will only produce only 2V from each mosfet to the transformer so the is unactive in this circuit? then the previous kachew inverter is theoritical working (exclude latest modification) and the mosfet is acts as a switch?? and for 200w output the transformer have to be 12V and 1Amps??thanks for your reply. ;) Quote
audioguru Posted September 6, 2006 Report Posted September 6, 2006 then what u means is the mosfet will only produce only 2V from each mosfet to the transformerYes. An N-channel Mosfet is turned on by making its gate about +10V higher than its source. Your circuit had the input going to +12V from the 4001 gate, so its source which is connected to the transformer goes up to only +2V. so the is unactive in this circuit?The other end of the transformer winding is connected to a turned-off Mosfet, so no current flows and the circuit does nothing.then the previous kachew inverter is theoritical working (exclude latest modification) and the mosfet is acts as a switch??Yes, it was correct since the transformer's center-tap connected to +12V and the drains of the Mosfets pulled their side of the transformer's winding to ground. and for 200w output the transformer have to be 12V and 1Amps??No. 12V and 1A is only 12W. Your transformer must be 200W for the output plus maybe 40W for heating the circuit, and must be 10V to make the peak voltage of the modified sine-wave high enough. So the transformer must be 10V-0-10V at 240VA which is 24A. A BIG transformer. Quote
kachew Posted September 9, 2006 Report Posted September 9, 2006 hi audioguru, i think i know what is kachew tryin to deliver.... ;D the concept can be found in any power electronics book ;D ;D and i also attach a circuit i think is similar to your concept using the cd 4001....and audioguru can u try to explain your circuit using the cd 4001 and mosfet as a switch? the center tap transformer is similar to 2 transformer circuit as i attach? thanks for your information and reply ;D ;DFigure.rar Quote
kachew Posted September 9, 2006 Report Posted September 9, 2006 sorry to introduce myself, actually i am using kachew's account , i am sonny.... Quote
audioguru Posted September 9, 2006 Report Posted September 9, 2006 Hi Sonny,You make everything very confusing when you use Kachew's account. You should register on this site as yourself. Then login as yourself each time.You attached a DOC file instead of a GIF or PNG file for your schematics, and you compressed it as a RAR. Just attach the schematics as a GIF or as a PNG.The CD4047 has an oscillator output and has two opposing Q and Q-not outputs which are the oscillator divided by 2. When you gate those outputs with CD4001 NOR gates then the outputs of the gates drive Mosfets with the correct timing for a modified sine-wave inverter. Quote
kachew Posted September 10, 2006 Report Posted September 10, 2006 hi audioguru,may i know the transition of the pulse where both mosfet are turned off? you only shows the transition where 1st and second mosfet are turned on....and i would also like to ask why we want to use the drain source of the mosfet to ground the center tap transformer?thanks for your reply :D :D Quote
audioguru Posted September 10, 2006 Report Posted September 10, 2006 may i know the transition of the pulse where both mosfet are turned off?I showed it a few days ago. Here it is again clearer.why we want to use the drain source of the mosfet to ground the center tap transformer?What is a drain source? A Mosfet has a drain pin and a source pin. On these N-channel Mosfets, the sources are connected to ground and the drains are connected to the ends of the transformer winding. The center-tap is connected to +12V. Here is your schematic. Quote
