Jump to content
Electronics-Lab.com Community
a very simple FM Tx
walid
the following FM circuit
I have tree questions:
1- what the function of the 1 n cap
2-why tapping the coil, why not connecting the antenna directly to the collector
3-what the function of the 1.8p cap, and why it is so small
Hi Walid,
That is an extremely simple FM transmitter circuit. Did you make it? How is its performance?
1) The 1nF cap makes the transistor a common-base amplifier at radio frequencies where the emitter is its input and the collector is its output.
2) The coil and capacitor in parallel with it is the tuned circuit that determines the RF frequency. The antenna is connected to it so anything that gets near or touches the antenna changes the capacitance and changes the tuned frequency. When the antenna is connected to a tap on the coil then the change of tuned frequency isn't as much, but then the range of the transmitter isn't as far.
3) The 1.8pF cap provides positive feedback so the transistor oscillates. It is in parallel with the transistor's capacitance and the wiring capacitance so the total capacitance might be about 10pF. 10pF is not small at 100MHz where it has a reactance of 160 ohms.
Link to comment
Share on other sites
Hi guru
Maxim's VCO IC uses a varactor diode (it changes its capacitance when its voltage is changed) to frequency-modulate and to tune its carrier.
ok, i agree
my circuit did not using a varactor diode, there is no varactor diode
i think that a p-n junction do this, is this true and how?
Link to comment
The datasheet for the transistor that is used in your project and for most other small transistors shows the transistor's change of its capacitance with voltage change, like a varactor diode.
The input audio causes the transistor to conduct more and less which changes the voltage across it and changes its capacitance.
Link to comment
Hi guru
This circuit uses a common-base amplifier. There are many other kinds of oscillator circuits. The capacitor makes the base at 0V for RF frequencies. If it is removed then the circuit probably won't oscillate
why the circuit probably won't oscillate, can you please, explain this point more.
The antenna impedance match to the circuit's output impedance is poor, but it is simple and it works
What would u do to improve the matching between o/p and antenna?
The base input impedance of the transistor at low audio frequencies is its beta of about 200, times the emitter resistance of 220 plus its internal emitter resistance = 44.5k ohms. It is in parallel with the two 47k resistors also in parallel, so the load on the mic is 15.4k ohms.
beta = 200, are u guess it or depend on some source or you consider any general purpose transistor's beta as approx 200.
also you calculate the internal emitter resistance (re) as beta X re =500 ohm, that is re = 500/200 =2.5 ohm, frome this:
25/Ic=2.5 ==> Ic = 10 mA, is these values from datasheets, I search for BC547 datacheets and find many copmanies, please provide me with your datasheet or tell me from any comany.
It is complicated to calculate how much is the output voltage and current because tapping down the coil reduces the output voltage into the low impedance antenna but provides a better impedance match so the collector voltage swing is much higher
But with tap, the coil acts as a step down transformer?
Are you mean the capacitance between B and E?
thank you alot
Link to comment
The transistor needs a change of base to emitter current to be an amplifier and to oscillate. If the base voltage is not secured with a capacitor to ground then it will also have its voltage changed when the positive feedback changes the emitter voltage, then there is no change in base to emitter current.
I would add an RF amplifier that would have a lower output impedance than the oscillator. It would also isolate the antenna from the oscillator so the frequency wouldn't change when anything gets near the antenna. Then I would add a series or pi LC impedance-matching network at the output which would also reduce harmonics.
The Re of a silicon transistor is approx. 26/Ie in mA, which is about 2.6 ohms. The beta ranges from 110 to 800 so I picked 200. You can check its accuracy by looking at the input impedance of a 2N3904 transistor on its datasheet since it is about the same as a BC547. At 10mA the input impedance of a typical 2N3904 is 500 ohms.
Yes, it is an auto-transformer (single tapped coil).
The transistor's collector is connected to the tuned circuit. The collector to emitter capacitance changes which changes the tuned frequency at the collector.
Link to comment
Hi guru
I feel that i not understand what you want to say.
Lets analyze that statement:
I assume that VE = 3v
VB = 3.7v
positive feedback changes the emitter voltage to say 4 v
so VB = 4.7v
now what that cap do to maintain VB to 3.7 v
thank u guru
Link to comment
Hi Walid,
A filter capacitor needs time to charge or discharge in order for its voltage to change. At 100MHz its value makes a good filter so its voltage doesn't change.
At 7.5kHz and lower audio frequencies then the value of the capacitor makes a very poor filter so its voltage can change to allow audio to modulate the base of the transistor.
In my FM transmitter I used a 470pF filter capacitor to allow modulation up to 15kHz.
Link to comment
  • 2 weeks later...
Hi guru
15.4k ohms.
This is good, but I want to introduce the effect of the 1nF cap on the lower 47Kohm.
The reactance of that cap at freqs from 300Hz t0 15Khz is 10.6 Kohm to 53 Kohm
47K // 10.6K  = 8.65 K, and
47K // 53K = 24.9K
so VB is not constant at VB = 9 * 47/(47+47) = 4.5v as i was think
it is really changes from 1.4V to 3.12V with the audio freq
Now Zin (total) = ZB//RB1//RB2
since RB2 equivalant is change from 8.65 K to 24.9K
so Zin change
please comment.
impedance match so the collector voltage swing is much higher.
I agree that it is complicated to calculate how much is the output voltage and current, lets
assume them and investigate the tapping effect on them:
If the output voltage = 5mV rms at freq 100MHz as shown in the Fig. below, how much voltage reach the antenna?
and what the value of the impedance the antenna see, if the coil is 330nH and its XL = 207 ohm at 100MHz?
thank u guru
Link to comment
Hi guru
First thank u for the figures from which i can see that the 1 nF has no resonable effect at AF.
but u may not see this question
index.php?action=dlattach;topic=9275.0;i
thank u guru
these flowers are for you
Link to comment
How do you know you have crossed the finish line with an oscillator? I seem to think that general test lab equipment cannot tell the whole story. I cannot believe these mass produced behemoth bluetooths with Intel Pentium 4's and Windows spyware can measure accurately enough for me.
If you know the oscillator frequency, it's probably better to make your own measuring circuits. An embedded application.
Link to comment
Hi Walid,
Thanks for the white roses. They are fresh and smell nice. ;D
The tuned circuit at the collector of the transistor is resonant and tries to be a high impedance. The coil is an auto-transformer and the 50 ohm antenna is multiplied by the square of the turns ratio so appears as 5 x 5 x 50= 1250 ohms at the collector.
I think the power output is higher than if the antenna is connected directly to the collector.
Link to comment
Hi guru
lets do it again
at 106MHz, L =330nH  and C=6.8pf, we have
XL = 2 pi f L = 220 ohm
XC= 1/(2 pi f C) = 220 ohm  (resonance)
Ztot = (XL*XC)/(XL+XC) = 110 ohm
I think it is wrong calc, Ztot must be zero because XL = j w L
and XC = -1/j w c
I don't know what to do............
IF the LC impedance = 110 ohm as before, and the antenna impedance = 50 ohm
110/50 = 2.2
the turns ratio = sqr(2.2) = about 1.5:1  which equivalent to 3:2  = 6:4
if the coil was 6 turns then the tap must be at the fourth turn and not the fivth turn to have better impedance matching.
please guru correct me
Link to comment
Hi guru
I go to google and search for LC Resonance and one of them was:
http://www.pronine.ca/lcf.htm
It is a calculator
substitute L=330n and C=6.7p
u will have f=106 MHz and Zo=220 ohm as i calculate it, it is not nearly infinite ohms
It is very important to me to correctly calc the o/p Z of the oscillator because i want to discuss with u the pi C-L-C filter between this osc and the 50 ohm antenna from this site:
http://hem.passagen.se/communication/antenimp.html
and to ask u why u don't use it in your FM Tx
don't worry i understand 95% of what he said but still to know how to cal the o/p Z of the oscillator to match it with the antenna
I make a page in MATHCAD for quickly calculations
thank u guru
Link to comment
Hi Walid,
The calculator you found is WRONG!
It has the wrong formula for the impedance at resonance of a parallel LC.
You shouldn't calculate things at such a high frequency because you don't know how much stray capacitance is in parallel with your C, and you don't know how much inductance is in the wiring of the L.
I tested my FM transmitter only one day and didn't improve it by adding a matching network at its antenna. Its range and sound quality are much better than I expected and since my FM band is full, it causes interference. It is illegal (and not nice) to cause interference here.
Here is another formula for the impedance at resonance of a parallel LC:
Link to comment
Hi guru
yes I agree, it It has the wrong formula and they calc it as 220 and i calc it the first time as 110 and mistake when tell you it 220 ( I was hurry)
yes, I know, but still must calc it to know the o/p impedance to correctly fit the matching network, then may modify it lettle to compensare for the stray capacitance and inductance
I calc it, using your formula, look below:
Link to comment
hi guru
If they cancel then the Z is zero not infinity
I know it is not zero
the ohmic resistance of the coil wire and cap materials .. etec
please look, the man who do this: http://hem.passagen.se/communication/antenimp.html
say:
the matching between Zout and the 50 ohm antenna using Pi C-L-C filter
if Zout is infinity, how can he put the matching network
to design the Pi C-L-C filter you must know Zout??
Your last answers on this topic were not very good
it takes me up then down, I'm confused now
thank u
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
