Jump to content
Electronics-Lab.com Community
Posted
I have to analyse this circuit and know what it does...
I think its an transconductance amplifier...but I need to know how to find the transconductance gain of it....
the circuit its int the following link
Posted
Im studying realimentation in electronic circuits, I know that for have transconductance gain the circuit have to be of serie-serie type....I have V in the entry and I in the out of it.
To have a transfer function of it I divided in two parts: A=>the amp-op and the part of diodes and transistors and 2) Beta=>the two Resistances of 1kohm.
This way I think I can calculate the transfer function of the circuit to a form A/(1+Beta*A)
In the diodes and transistor part the gain it
Posted
The schematic is small and is a very fuzzy JPG file type. It would be much clearer if it was made as a GIF or PNG file type.
I can hardly see the part numbers. I cannot see the inverting and non-inverting symbols on the opamp.
Why did you post the schematic "over there"? Please attach a clear schematic to your reply here.
Posted
Thank-you, Upsurt.
Your new schematic is very clear as a GIF file type. But it was huge so I reduced its size, cropped it and made some of its dotted lines solid lines.
I don't think the resistor in series with the load is needed. The voltage gain of the amplifier will be 1 when the load resistance is very low.
I also don't think the capacitor is needed because the output transistors are emitter-followers with a very wide bandwidth, very low phase shift and no voltage gain.
I changed the 47k feedback capacitor to 100k so that the output impedance of the amplifier can be higher.
Posted
Thanks for the help audioguru! :)
Where I have more difficult anaslysing the circuit its in the opamp part... I dont know how to calc the transfer function of it  ???
Posted
The opamp has an extremely high input resistance because its input transistors are FETs. It has an open-loop voltage gain of typically 200,000 so the resistors set the closed-loop gain with their negative feedback.
Posted
I made the 1k resistor on the inverting input R3 because you have multiple R2's
From writing the nodal equations for the opamp and solving:
Without the capacitor across the feedback resistor G(s) = (R2 + R3)/R3 = 48
With the capacitor  added G(s) = (R2 + R3 + R3.C1.R2.s)/(R3 + R3.C1.R2.s)
Imput impedance 1k, output impedance ~ 24m Ohm
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
