Hello from NE PA,
Where do you all find data on MOSFET transistors?
I look on ebay  for MOSFETs but most do not have specs so you have to search for
a data sheet, download it, open it, and find it's not what you want!
I am looking for an n channel  eMOSFET for a class D amplifier that has 150 to 200 volt
drain to source. Some 20 to 40 ma for current.
I find lots of power switching MOSFETs references.
Are there any good books on using MOSFET transistors?
thanks in advance,
HarryA
An audio amplifier with a supply voltage as high as 200V will produce about 500W into an 8 ohm speaker and produce almost 12A peak, not a few milli-amps.
Oh, is your amplifier going to use an old output transformer that has not been used for 50 years? Then its output power might be 1.8W into 8 ohms.
Thanks for the reply.
I have a a 400 microsecond pulse every 20 ms that I wish to amplify. I need about 100 volts so I an thinking I need a 150-200v transistor.
I need to preserve the varying amplitude so I can not just emulate it with a switching transistor.
Speaking of transformers; I tried amplifying it with a 2n7000 n channel MOSFET using an audio transformer in reverse (input into the 8 ohm windings ) but I could not get a decent output pulse in spite of using various combination of diodes.
HarryA  \../
To close this out. I found mouser.com to be helpful as they have a system of filters that makes it easier to find what you want - with some effort.
I ordered the n-channel ZVNL120 eMOSFETs from then; 200v and 120ma.
The book "Electronic Devices and Circuits" by "Schaum's easy outlines" has good information on circuit design using bipolar, FETs, and MOSETs tranistors.
