Jump to content
Electronics-Lab.com Community
NI GPIB-USB-HS - Issues - no original - fake - HACK? - firmware replacement from orginal
max-bit
As in the topic, the problem of a large number of adapters : NI GPIB-USB-HS
From software version 17.6 (NI 488.2) all Chinese adapters (mainly bought on ebay) are detected as not genuine.
So far the solution is to use software version 17.0 (which is also not available on the NI website).
But is this the only solution?
According to me, there should be at least 2 more:
1 - finding a module (entry) in the software which, after detecting an incorrect number, throws this error.
2 - (or even better) find the entry in the adapter's flash memory where the serial number is and change it
Has anyone tried to deal with the topic?
So far, I have not been able to find such an entry neither in the software nor in the memory of the adapter, most likely this value is encrypted in some way.
and ...
... programmed eeprom 24lc256 (from original unit) serial no. changed in NI MAX but software still sees it as not genuine? WTF? (on version NI MAX > 17.0 ... actual 21)
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
