Jump to content
Electronics-Lab.com Community
control circuit for solar panel tracker
Good day all
I have very basic electronic knowledge and can build basic circuits. I am building a tracking device that will turn my solar panel from east to west during 8 hours.
The device will be powered by a 12v dc motor that will turn a threaded rod to move the panel through about 90 degrees.
the motor will be controlled by a 12 relay.
I need a circuit diagram that will power the relay to run the motor for 2 seconds at a time, but I would like to be able to adjust the time between runs from approx 30 sec to 5miniutes. also if possible, the motor must reverse after 8 hours until stopped by a limit switch.
Any help would be appreciated
Thank you
Redge
Link to comment
Share on other sites
This is easier to do today with microcontollers like the Arduino UNO for example. Else you can  fabricate it from logic circuits using a number of timers like the MC1455 (a newer NE555).  I  can help you with either approach but recommend the microcontroller. If you are not familiar with them it would be a good project to learn on.
You will notice there are a lot of solar trackers on Ebay for less cost then to make one.
Link to comment
13 hours ago, HarryA said:
This is easier to do today with microcontollers like the Arduino UNO for example. Else you can  fabricate it from logic circuits using a number of timers like the MC1455 (a newer NE55).  I  can help you with either approach but recommend the microcontroller. If you are not familiar with them it would be a good project to learn on.
Thank you HarryA
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
