Jump to content
Electronics-Lab.com Community
DC Timer
Leslie
More information is needed.
The ICM7555 can probably do this but a potentiometer will be needed to adjust the delay.
A microcontroller can be used to build a more flexible timing device but will need a voltage regulator (5V or 3.3V) and an output buffer to interface with the 18V devices.
Link to comment
Share on other sites
If you are handy with a soldering iron you can get a push button switch with potentiometer on ebay.  for example:
https://www.ebay.com/itm/113927101102?hash=item1a86959aae:g:TyAAAOSw6ShdqKXJ&amdata=enc%3AAQAHAAAAsCTccvK8zt8P7ay7xO2JNnQVqK54hb11np%
You would need to match the potentiometer on the switch with the one on the timer board.
You  could replace the potentiometer and switch on a timer board like this perhaps:
https://www.amazon.com/Module-Adjustable-Timing-Switch-1-10sec/dp/B07SL5HBZ9/ref=sr_1_58?crid=3806JFZG2WCBO&keywords=time+delay+board&qid=1670774252&sprefix=time+delay+board%2Caps%2C129&sr=8-58
Look for one with the delay you need.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
