That topic is outside the purview of electrons in a circuit.How photon are made how they become useful in generation electricity photo voltaic cell
Voltage is not "pressure". Pressure is a mechanical and hydraulic term, not an electrical term. Current is rate of charge carrier flow. Knowing that, you should be able to answer your question about "electron increase".The wire get burn at at higher current.
If voltage increase that mean pressure increase?
and current increase mean electron increase?
Personally, though the term "pressure" may not be an appropriate term to describe Voltage, it's about as good an analogy as can be found when teaching basic electronics. I often used plumbing concepts to convey Ohms Law relationships of E, I & R. Students sometimes need a tangible reference to grasp a concept.
Chris
I use several good texts on electrical science and some good physics books. Then I evaluate what the texts aver. Keep in mind that there is a lot of technical "slang" that does not correctly describe what is happening. Things like "current flow" or "space walking".How should i study these topic?
Where were you when I was arguing exactly this point, and others insisted that Ohms law applies to every component including diodes, transistors, inductors and capacitors, and even "negative resistance" devices.By the way, Ohm's law is not E=I*R and all its variations. That is the definition of resistance. Ohm's law refers to the resistive linearity of a material. In other words, it is a material property. I can back up what I said if necessary.
Ratch
Above sentence does not make sense.So, what we say few words for electrons in in Al and copper wires?
Remember what I said about capitalizing the beginning of sentences?why copper wire is preffer?
What do you mean by the above sentence?it has lot of free electron than aluminum silver?
Bob
Can we apply ohms law on other than linear resistance like inductor bjt?
only on linear component like resistance.
what are other component with linearity?
All components in an electronics circuit are governed by Ohms Law.
Here is the thread. Be prepared to be dumbfounded.
The basis is this quote:
I disputed this, thinking it was non-controversial, and got basically no support for my position.
https://www.electronicspoint.com/threads/ohms-law-or-not-ohms-law-that-is-the-question.252367/
Bob
