Hi,
Can anyone tell me if the incoming of this circuit (attached) is 240V AC, how is the input of the zener diodes 15V? Can a RC circuit drop voltage?
If 60Hz, the 470Ω resistor plus the 5643Ω impedance of the 0.47μF results in 6113Ω total opposition to alternating current.
Calculate as if it was only a 6113Ω resistor in the circuit.
The unmarked capacitor to the right also presents a impedance.
Both in series to power applied at S1 and S2 does the division as if it were resistors.
That is correct, but doesn't get you any closer to determining what the AC applied voltage and frequency is since you don't know how much current is allowed in the zener.By my very rusty calculations the vector summation of a 470 ohm resistor and a 5643 ohm capacitor reactance is 5662 ohms.
Certainly. But it is unsafe to do so to provide a low voltage DC from the mains supply. Better to spend a few bux for a transformer, or use a transformer-isolated, high-frequency switching, power supply. Component failures in the type of supply you posted are typically accompanied by exploding capacitors, melted conductors and fire.Can a RC circuit drop voltage?
Not to forget deadly elecrical shock to persons!Component failures in the type of supply you posted are typically accompanied by exploding capacitors, melted conductors and fire.
