So, I have decided to try another guitar pedal project, but first. I have a few questions:
I decided I will use the attached schematic as my template. What I mean is that I will use this schematic as my starting point, but I will be making changes to it- hence my questions:
I recognize that when using an Op Amp, it is important to know the pin mappings, because not all of them has the same configuration. I also know one has to be cognizant of single vs dual op amps.
Let's assume I want to try a few different op amps in the schematic referenced in the attached picture. I will make sure that I make the necessary chnages in order to make sure the pin mappings are correctly wired up to.
In the schematic, the + input of the op amp, receives its biasing from the lead coming from R41 (the 1M resistor). That voltage coming from there is roughly half of 9 volts, which is 4.5 volts
Can I assume that this voltage (the 4.5 volts ), will work with the different op amps I use. Specifically, I have the following op amps:
UA741
J4558D
LF353N
I guess what I am wondering about, is whether I have to worry about the bias voltage going into the + input of the op amp, or can I assume that the 4.5 volts will work with each op amp?
Thank-you
UA741
J4558D
LF353N
Thank-you
