Step Down Bypass
BGT
Oct 22, 2020
15
Hopefully my little diagram will make sense as to what I would like to do. My question is: would this be a safe way to switch between 12v & 9v (DC) or would this somehow damage the step down converter ?
the convertor is:
XL4015 Constant current/Constant voltage, Adjustable 5A Step Down Buck
danadak
Feb 19, 2021
1,085
Short answer is no. This would potentially dump current into the output of the
converter. No predicting what it would do.
A Schottky diode in output of converter then tie that to bypass switch output
and load should work. Note consult datasheet for converter, if it needs a minimum
load to stay in regulation. Note diode will drop the converter output when in use by its
forward V drop, so converter should be slightly adjusted, its output V, to
minimize diode V loss.
Note also the Schottky Vf versus T is ~ -1 to -2 mV / C, depending on Schottky
type.....
Regards, Dana.
BGT
Oct 22, 2020
15
What sort of size spec of diode should I be looking for ?
Bearing in mind I have access to a large amount of electrical bits and pieces, what am I looking for ?
bertus
3,852
Hello,
Try this, as @danadak suggested:
The SR diode will drop about 0.5 Volts at 5A.
Bertus
  • SR520_SR560.pdf
Delta Prime
Jul 29, 2020
2,989
Careful now... Zeners and Schottky
Schematic symbols could be rather confusing.
Delta Prime
Jul 29, 2020
2,989
Even worse! As far as confusing. This is on a data sheet
Explicitly for a Schottky Diode.
Look at the schematic symbol they have chosen.
