PWM on 12volt winch?
Maglatron
Jul 12, 2023
2,025
Quote
That's reasonable. But applying the same factor of 5, that means the OP would be looking to source one rated at 5 x 114A = 570A !
hmmm,
Mr Alec_t could you skip over to the IR2110 thread, I have a question!
Maglatron
Jul 12, 2023
2,025
ok been searching all day can anybody tell me where to get a variable speed winch or how to determine the type of motor that I have, to then move on to how to tackle the task of making a PWM controller please, thanks
kellys_eye
Jun 25, 2010
6,512
Spec says it's a permanent magnet motor. Full pull current is 200A at 12V.
Maglatron
Jul 12, 2023
2,025
good man! I missed that, so what does that suggest, motor type wise? wait that was stupid it's a permanent magnet motor can you you PWM on that?
kellys_eye
Jun 25, 2010
6,512
The x5 would only apply to 'dodgy' source units. As per Bluejets saying 'quality' product, such a device would work when rated at 250A or even 200A with suitable fusing/breaker for protection.
kellys_eye
Jun 25, 2010
6,512
Personally I'd use a 100A device (with suitable thermal/overcurrent trip, resettable) and be careful how I used it. I'd also use a bypass switch to run it at full current when that was necessary - probably not very often.
can I buy or is it better to make a controller?
Even a low current controller can be modified to work at MUCH higher currents by changing the switching device (probably a MOSFET) for one - probably a few wired in parallel - device rated for much higher current.
You can get N-channel MOSFETs rated at 30V and 500A (IRDS(on) value of 0.0007ohms!) for £1.20 at Farnell.
Use any good component supplier and their parametric search engines.
Maglatron
Jul 12, 2023
2,025
I have bought the winch a while ago and it's being stored at my friends till I come to use it. I'm just getting ready for when I do use it.
this seems like a good way to go, any controllers in mind? I would like push buttons to gradually increase current with each press and one to do down or a knob pot
Maglatron
Jul 12, 2023
2,025
so that is really taking my interest can you draw up a rudementary picture with labels on a paint diagram please like a rough guide of the steps involved, thanks
Martaine2005
May 12, 2015
5,285
Winches are geared motors. Slow speed and high torque.
What is the purpose of PWM?. The winch is already designed for max torque at a sensible RPM.
Are you taking the gearbox away?. That’s the only way to achieve what I think you want. Then, you’ll lose the torque and get high RPM.
I personally don’t think you’ve thought this through!
Maglatron
Jul 12, 2023
2,025
No I want to gradually increase the speed of the winch, not just on or off, to take out the jerk, for that project a jerk would cause damage! when the winch turns on it immediatly goes from 0 m/s to 10.5 m/s I need it to be gradual! I have thought about it a lot to be fair
Maglatron
Jul 12, 2023
2,025
so just use a massive pot?? know where to get one looking on mouser no joy
Maglatron
Jul 12, 2023
2,025
Its SCR is rated only 3A, not 200 !
oh I put the max amperage at 20 and multiplied by 12 for power equals 240watt so I thought the 300watt pot would work, I don't know what SCR is can you recommend a different one1706560264004.png
Maglatron
Jul 12, 2023
2,025
oooohhhhh I realised what I just did, derrrr 20 amp at no load!
Maglatron
Jul 12, 2023
2,025
any suggestions, reconsidering the modified controller with the parallel mosfets need abit of help with it though, thanks
