help with IR2110 chips
Maglatron
Jul 12, 2023
2,025
so first of all, I have to stick the rest of the magnets and mount the new wheel and mount the other coil that I have and run some experiments. I don't want to get too far ahead of myself! thanks
Maglatron
Jul 12, 2023
2,025
more glue just come so I'll see if I can get the rest of the magnets on and take some snaps! anout mount the other 7ohm coil
Alec_t
Jul 7, 2015
3,820
I think there are 28 layers = (20mm / 0.7mm)
Looks right. I was thinking 14 per cm but omitted the 2cm. My bad. Guestimate re-called from this thread.
With 2800 neat turns, average diam 3cm, turn circumf = pi*3 cm, wire length = pi*3*2800 = 264 metres. Doesn't sound right.
If 264 metres, with copper density 8.94g/cc, that would weigh 909gm. So we're out by a factor of nearly 2.
Yes. Impedance of an inductance impedes current flow so results in a voltage drop.
Maglatron
Jul 12, 2023
2,025
ok now I have the magnets stuck and will upload picutes after 6, its dinner in 15mins and I actually do have that information didn't think to check1707410692540.png
Maglatron
Jul 12, 2023
2,025
so I might add that they are not the neatest wound coils in the world but I think they shall suffice to be fair!
I've already said I wouldn't buy anything more yet :)
ok I will take it on board, no more buying as of the moment!
Maglatron
Jul 12, 2023
2,025
does look rather good perhaps combining the information that it does give with core dimensions for instance we can find a better number more realistic to that of real life, thanks
Maglatron
Jul 12, 2023
2,025
heres some photos of the very naked machine along with both sides of the new wheel, (still needs mounting, two man job!) it might not look much but I didn't know what to snap when I had the camera! there are pictures of the hall effect sensor on one of them and the arduino that runs the screen for the RPM monitor you can see a bearing you can see quite a few trolley wheels and the coil that is mounted the next coil will go directly opposite and across from the first, any questions, feel free to ask!, thanks on pic 227 is the bearing bearly in view in a custom block thats made of metal
Maglatron
Jul 12, 2023
2,025
so last night when mounting the new wheel I had a disaster the thing broken some of the plastic so spent 45 mins this morning fixing and making more sturdy have to fit the coils and the run it up the balancing seems better with this new wheel thoughand so now it should be better than before
Maglatron
Jul 12, 2023
2,025
so the wheel is mounted and I mounted two coils they'er identical, however one makes 11volts AC and the othe makes near to 9volts AC going to try and reduce the gap between the coils and the magnets next but as of yet the initial reading doesn't differ that much from the 8 magnet-a-side wheel at similar speed 550rpm
Alec_t
Jul 7, 2015
3,820
If that's the open-circuit voltage, what do you get with, say, a 100 Ohm load resistor connected across the coil?
Maglatron
Jul 12, 2023
2,025
sorry for the crude drawing do I measure over the coil or with the resistor in series with the meter the grey is the resistor and the brown box represents the meter1707507988843.png
bertus
3,868
hello,
the resistor should be connected as the top drawing.
the voltage measured then will say something about the loss in the coil resistance
bertus
Maglatron
Jul 12, 2023
2,025
so at 600rpm it reads 11volts AC without resistor with resistor it reads 6.8volts AC working on the machine right now took the reading of the coil that put out most gut feeling tells me this is not too bad!! 100ohm resistor!
