why would this not happen with one diode? (thermal runaway)No.
The diodes will never be 100.000000000000000000 % equal. Therefore the diode with less pass volateg will also pass a higher current. The power dissipated by the diode will increase its temperature, which in turn further lowers the pass voltage which in turn increases curent and so on (link). This will lead to thermal runaway.
why would the thermal runaway not happen with only using one diode please? thanksNo.
It could happen. But in any well-designed practical circuit there is always something in series to limit the current to a safe level at which the diode can survive.why would the thermal runaway not happen with only using one diode please?
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
// Pin assignments
const int button1Pin = 2; // Button for Phase One
const int button2Pin = 5; // Button for Phase Two
const int button3Pin = 6; // Button for Phase Three
const int redLED1Pin = 1; // Red LED for Phase One
const int greenLED1Pin = 7; // Green LED for Phase One
const int redLED2Pin = 8; // Red LED for Phase Two
const int greenLED2Pin = 10; // Green LED for Phase Two
const int redLED3Pin = 11; // Red LED for Phase Three
const int greenLED3Pin = 12; // Green LED for Phase Three
const int escPin = 9; // ESC control pin
const int rgbRedPin = 13; // RGB LED red pin
const int rgbGreenPin = A0; // RGB LED green pin
const int rgbBluePin = A1; // RGB LED blue pin
const int voltagePin = A4; // ZMPT101B voltage sensor
const int currentPin = A5; // ACS712 current sensor
const int potPin = A6; // Potentiometer
const int togglePin14 = 14; // Toggling pin 14
const int togglePin15 = 15; // Toggling pin 15
// LCD initialization
LiquidCrystal_I2C lcd(0x27, 20, 4); // Adjust the address as necessary
// Variables for button states
unsigned long lastPressTime1 = 0;
unsigned long lastPressTime2 = 0;
unsigned long lastPressTime3 = 0;
int pressCount1 = 0;
int pressCount2 = 0;
int pressCount3 = 0;
// Phase flags
bool phaseOneActive = false;
bool phaseTwoActive = false;
bool phaseThreeActive = false;
// Toggling state for Phase One
bool toggleState = false;
// Timing variables for toggling
unsigned long lastToggleTime = 0;
const unsigned long toggleInterval = 20; // 50Hz -> 20ms for 50Hz
void setup() {
// Initialize pins
pinMode(button1Pin, INPUT_PULLUP);
pinMode(button2Pin, INPUT_PULLUP);
pinMode(button3Pin, INPUT_PULLUP);
pinMode(redLED1Pin, OUTPUT);
pinMode(greenLED1Pin, OUTPUT);
pinMode(redLED2Pin, OUTPUT);
pinMode(greenLED2Pin, OUTPUT);
pinMode(redLED3Pin, OUTPUT);
pinMode(greenLED3Pin, OUTPUT);
pinMode(escPin, OUTPUT);
pinMode(rgbRedPin, OUTPUT);
pinMode(rgbGreenPin, OUTPUT);
pinMode(rgbBluePin, OUTPUT);
pinMode(togglePin14, OUTPUT); // Toggling pin 14
pinMode(togglePin15, OUTPUT); // Toggling pin 15
// Initialize LCD with the correct parameters
lcd.begin(20, 4); // 20 columns and 4 rows
lcd.backlight(); // Turn on the backlight
// Initial state: Phase One is inactive
digitalWrite(redLED1Pin, HIGH); // Red LED on, indicating inactive
digitalWrite(greenLED1Pin, LOW); // Green LED off
void loop() {
// Check button 1 (Phase One)
handleButtonPress(button1Pin, lastPressTime1, pressCount1, phaseOneActive, redLED1Pin, greenLED1Pin);
// Check button 2 (Phase Two)
handleButtonPress(button2Pin, lastPressTime2, pressCount2, phaseTwoActive, redLED2Pin, greenLED2Pin);
// Check button 3 (Phase Three)
handleButtonPress(button3Pin, lastPressTime3, pressCount3, phaseThreeActive, redLED3Pin, greenLED3Pin);
// Toggle pins 14 and 15 for Phase One if active
if (phaseOneActive) {
unsigned long currentTime = millis();
if (currentTime - lastToggleTime >= toggleInterval) {
toggleState = !toggleState;
digitalWrite(togglePin14, toggleState ? HIGH : LOW); // Toggle Pin 14
delayMicroseconds(2); // 2µs dead time
digitalWrite(togglePin15, toggleState ? LOW : HIGH); // Toggle Pin 15
lastToggleTime = currentTime;
// Update Phase Two display
if (phaseTwoActive) {
float voltage = analogRead(voltagePin) * (5.0 / 1023.0); // Adjust for actual voltage
float current = analogRead(currentPin) * (5.0 / 1023.0); // Adjust for actual current
float power = voltage * current; // Calculate power
float frequency = 60.0; // Placeholder for frequency, replace with actual reading
lcd.setCursor(0, 0);
lcd.print("Voltage: " + String(voltage) + "V");
lcd.setCursor(0, 1);
lcd.print("Current: " + String(current) + "A");
lcd.setCursor(0, 2);
lcd.print("Power: " + String(power) + "W");
lcd.setCursor(0, 3);
lcd.print("Freq: " + String(frequency) + "Hz");
// Control ESC with potentiometer
if (phaseThreeActive) {
int potValue = analogRead(potPin); // Read the potentiometer value (0-1023)
int escValue = map(potValue, 0, 1023, 1000, 2000); // Map to 1-2ms pulse width for ESC
analogWrite(escPin, escValue); // Send PWM signal to ESC
// Function to handle button presses for each phase
void handleButtonPress(int buttonPin, unsigned long &lastPressTime, int &pressCount, bool &phaseActive, int redLED, int greenLED) {
if (digitalRead(buttonPin) == LOW) {
if (millis() - lastPressTime < 500) { // Button press within 0.5 seconds
pressCount++;
} else {
pressCount = 1; // Reset count
lastPressTime = millis(); // Update last press time
// Check for double press
if (pressCount == 2) {
if (!phaseActive) {
// Activate phase
phaseActive = true;
digitalWrite(redLED, LOW); // Turn off red LED
digitalWrite(greenLED, HIGH); // Turn on green LED
} else {
// Deactivate phase
phaseActive = false;
digitalWrite(redLED, HIGH); // Turn on red LED
digitalWrite(greenLED, LOW); // Turn off green LED
pressCount = 0; // Reset count after toggling
#include <Wire.h> // Include the Wire library for I2C communication
#include <LiquidCrystal_I2C.h> // Include the LiquidCrystal_I2C library
// I2C Pin Assignments
const int sdaPin = A2; // SDA pin
const int sclPin = A3; // SCL pin
// Create the LCD object with the I2C address
// Pin assignments
const int button1Pin = 2; // Button 1
const int button2Pin = 5; // Button 2
const int button3Pin = 6; // Button 3
const int redLedPhase1Pin = 1; // Red LED for Phase 1
const int greenLedPhase1Pin = 7; // Green LED for Phase 1
const int redLedPhase2Pin = 8; // Red LED for Phase 2
const int greenLedPhase2Pin = 10; // Green LED for Phase 2
const int redLedPhase3Pin = 11; // Red LED for Phase 3
const int greenLedPhase3Pin = 12; // Green LED for Phase 3
const int rgbRedPin = 13; // RGB LED Red Pin
const int rgbGreenPin = A0; // RGB LED Green Pin
const int rgbBluePin = A1; // RGB LED Blue Pin
const int escPin = 9; // ESC Control Pin
const int voltageSensorPin = A4; // Voltage Sensor (ZMPT101B)
const int currentSensorPin = A5; // Current Sensor (ACS712)
// Pin assignments for IR2110 control
const int ir2110Pin1 = 14; // First control pin for IR2110
const int ir2110Pin2 = 15; // Second control pin for IR2110
// State variables
bool phase1Active = false;
bool phase2Active = false;
bool phase3Active = false;
// Timing variables
unsigned long lastSignalToggleTime = 0; // Time of the last toggle for Phase 1
const unsigned long toggleInterval = 20; // 20 ms for 50 Hz
const unsigned long buttonPressInterval = 1000; // 1 second for button press detection
unsigned long buttonPressTime[3]; // Store button press times for debounce
void setup() {
// Initialize Serial Monitor
Serial.begin(9600);
// Initialize pin modes
pinMode(button1Pin, INPUT);
pinMode(button2Pin, INPUT);
pinMode(button3Pin, INPUT);
pinMode(redLedPhase1Pin, OUTPUT);
pinMode(greenLedPhase1Pin, OUTPUT);
pinMode(redLedPhase2Pin, OUTPUT);
pinMode(greenLedPhase2Pin, OUTPUT);
pinMode(redLedPhase3Pin, OUTPUT);
pinMode(greenLedPhase3Pin, OUTPUT);
// Set the IR2110 pins as output
pinMode(ir2110Pin1, OUTPUT);
pinMode(ir2110Pin2, OUTPUT);
// Initialize Wire (default pins A4 for SDA and A5 for SCL)
Wire.begin(); // No parameters needed
// Initialize the LCD
lcd.begin(20, 4); // Set the LCD dimensions
// Initial LED states
digitalWrite(redLedPhase1Pin, HIGH); // Red LED ON for Phase 1
digitalWrite(greenLedPhase1Pin, LOW); // Green LED OFF for Phase 1
void loop() {
// Check button states
checkButtons();
// Manage Phase One signals for IR2110
if (phase1Active) {
unsigned long currentMillis = millis();
if (currentMillis - lastSignalToggleTime >= toggleInterval) {
lastSignalToggleTime = currentMillis;
// Toggle the IR2110 control pins with 2 µs dead time
digitalWrite(ir2110Pin1, HIGH); // Set the first pin high
delayMicroseconds(2); // 2 µs dead time
digitalWrite(ir2110Pin1, LOW); // Set the first pin low
// Delay for the remaining cycle time
delayMicroseconds(19500); // Remaining time for 20 ms total cycle (20ms - 2us)
digitalWrite(ir2110Pin2, HIGH); // Set the second pin high
digitalWrite(ir2110Pin2, LOW); // Set the second pin low
// Update LCD with sensor readings in Phase Two
if (phase2Active) {
updateLCD();
// ESC Control in Phase Three
if (phase3Active) {
controlESC();
// RGB LED color cycling
cycleRGB();
void checkButtons() {
// Check Button 1
if (digitalRead(button1Pin) == HIGH) {
delay(50); // Debounce delay
recordButtonPress(0);
if (checkDoublePress(0)) {
togglePhase1();
// Check Button 2
if (digitalRead(button2Pin) == HIGH) {
recordButtonPress(1);
if (checkDoublePress(1)) {
togglePhase2();
// Check Button 3
if (digitalRead(button3Pin) == HIGH) {
recordButtonPress(2);
if (checkDoublePress(2)) {
togglePhase3();
void recordButtonPress(int buttonIndex) {
buttonPressTime[buttonIndex] = currentTime;
bool checkDoublePress(int buttonIndex) {
if (currentTime - buttonPressTime[buttonIndex] <= buttonPressInterval) {
// Ensure there was a previous press within the interval
return buttonPressTime[buttonIndex] > 0 && (currentTime - buttonPressTime[buttonIndex] < buttonPressInterval);
return false;
void togglePhase1() {
phase1Active = !phase1Active;
if (phase1Active) {
digitalWrite(redLedPhase1Pin, LOW); // Turn off red LED
digitalWrite(greenLedPhase1Pin, HIGH); // Turn on green LED
} else {
digitalWrite(redLedPhase1Pin, HIGH); // Turn on red LED
digitalWrite(greenLedPhase1Pin, LOW); // Turn off green LED
void togglePhase2() {
phase2Active = !phase2Active;
if (phase2Active) {
digitalWrite(redLedPhase2Pin, LOW); // Turn off red LED
digitalWrite(greenLedPhase2Pin, HIGH); // Turn on green LED
lcd.clear(); // Clear the LCD
} else {
digitalWrite(redLedPhase2Pin, HIGH); // Turn on red LED
digitalWrite(greenLedPhase2Pin, LOW); // Turn off green LED
void togglePhase3() {
phase3Active = !phase3Active;
if (phase3Active) {
digitalWrite(redLedPhase3Pin, LOW); // Turn off red LED
digitalWrite(greenLedPhase3Pin, HIGH); // Turn on green LED
} else {
digitalWrite(redLedPhase3Pin, HIGH); // Turn on red LED
digitalWrite(greenLedPhase3Pin, LOW); // Turn off green LED
void updateLCD() {
float voltage = analogRead(voltageSensorPin) * (5.0 / 1023.0); // Voltage conversion
float current = analogRead(currentSensorPin) * (5.0 / 1023.0); // Current conversion
float power = voltage * current; // Calculate power (W)
// Update the LCD display
lcd.print("Voltage: " + String(voltage, 2) + "V");
lcd.print("Current: " + String(current, 2) + "A");
lcd.print("Power: " + String(power, 2) + "W");
// Frequency calculation could be added here if needed
void controlESC() {
// Read the potentiometer value and map it to PWM range
int pwmValue = map(potValue, 0, 1023, 0, 255); // Map to 0-255 range
// Control the ESC with PWM
analogWrite(escPin, pwmValue);
void cycleRGB() {
// Add your RGB cycling logic here
You don't have any power-hungry diodes to worry about.but my circuit is fine right?
