It was supposed to adjust 0 voltI have not checked the circuit out but I hear what you say about RV1. What was it "supposed" to adjust ?
Holt
oh...the 0V problem...i have not noticed it because i don't use lower voltage than 3 volt. If i go home i check this with the old version, the new one is not finished yet.tesseract
Did you suffer from this 0V adjust problem with the original cct or is it just the newer version that does this ?
You can get them here: http://de.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=6612000 or you can order samples from TEXAS INSTRUMENTS like i did, ordered them sunday and got them tuesday- pretty fast from USA to Denmark.The PSU are not ready because i have problems to become the TLE2141 in Germany.
you could easily get rid of one of the wires if you rotate D9 90 deg, and move a couple of tracs a bitI improve a bit the bottom of PCB with a picture editor. If someone find some errors please tell me
Yes you have right, that is my problem, RS sell only to a company. But i found someone and he ordered it for me. I must wait only a few days and i have the parts.I dont know if it is possibel to buy from RS in Germany unless you are a registret compagny.
The original version uses a TL081 opamp as U2 and has the value of R10 completely wrong and it is connected to the wrong voltage.@GrahamG
i check the old version of PSU and and it is possible to adjust the voltage up to 0.0 volt.
In addition to the errors of the offset adjustment, the opamps are operating at supply voltages above their absolute maximum allowed voltage, the transformer and many resistors are overloaded at full output, the tiny Q2 transistor and single 2N3055 transistor are very much overloaded when the current is 3A and the output voltage is set low or is shorted.@audioguru,
I'll give you absolutely right, it may be the original PSU has errors, but i built it for about 2 years ?? ( with TL081, 1x2N3055 and i have used the shown PCB ) and it's work fine !
60W/12V= 5A. So the current regulator reduces the output voltage so that the current is 5.0A. The warning LED should turn on to warn you that the current regulator is reducing the voltage.I have built a 5A version of this power supply. It seems it's working in some way but there is one 'load' problem. When I connect the 12V/60W lamp to PS and set both potentiometers to max. values I get around 11V at the output.
Maybe opamp U2 is damaged from having its supply voltage too high for it.There is also another strange thing. I was measuring voltage levels in the circuit. Most values seem ok, except some values around U2. When both potentiometers are set to min. there is few milivolts on the pin 2 and 3 but at the output pin (6) there is 10V. I don't know from where this voltage come from if the input pins are almost at zero value.
The opamp is clipping with its output voltage as high as it can go. It is not regulating. Something is dragging down the output voltage so that the negative feedback to pin 2 has a voltage too low. U2 and the output transistors are supposed to have a voltage gain of 3.074 times and the output voltage will try to be 34.4V. The output of U2 will try to be 37V or more. Maybe the pins on the transistors are connected backwards.In the other hand, when I set potentiometers to the max then I measure around 3.5V at the pin 2 and 11.2V at the pin 3.
Make sure that the output of P1 goes down to 0V.Today finished assembling an updated power supply to the TLE2141.
I have the problem that HOLT.
In the zero position P1, I have the voltage at the output exactly 60 milivolt.
Situation RV1 result is not affected (not regulated).
Help please!!
is this capacitor Ok ?Like I said earlier, if the output capacitor C7 is an electrolytic type then it has "dielectric absorption" where it holds a charge even if it is shorted for a while. Use a film capacitor instead and add a resistor across the output to discharge it.
10uf/20%/100V is fine but a 50V or 63V capacitor will also be fine, will be smaller and cost less.is this capacitor Ok ? .....
