audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
The opamps should draw only a small amount of current from the negative supply. Your U2 or U3 opamp draws too much. Find it and look at how it is connected wrongly.just replaced R2 with higher watt, 5W and C2 with branded one still -2.1V with full load. output still stuck at 28.5V.
R7 should be 1.92V/3A= 0.64 ohms. The original project had a max putput current of 1.92V/0.47 ohms= 4.1A which is too high.R7 because i have difficulties to find one so i use 4 1Ω parallel is it problem?
We use 0.47 ohms then calibrate for a max current of 3A.
With 0.25 ohms then your max current is 1.92V/0.25 ohms= 7.68A which is much too high.
