Hi Audioguru,
as soon as I'm able to take 1 step forward, I have to take 2 steps back. ???
1st some background info you may require:
- Transformer is 25V AC rated 5amp continuous.
- Redwire's PCB.
- Your Parts listing - using the TLE2141.
- 2x 2n3055 and 0.47 10W.
Problems
1 - BD139 keeps popping when I load (short) the supply (with C1 now connected). While trying to adjust RV3 to set the max current, the DB139 pops. what I do is, adjust the current pot down to min, slowly adjust it up to about 2Amp, when I get there (only shorting for about 1 second), I adjust the VR3 down, (adjusting both in steps on after the other if you know what I mean?) until I have adjusted the pot to max, but when I have adjusted the current pot to max and I short the output, it pops the BD139, within 0.5 seconds.
2 - C7 popping, C7 has being blowing up quiet regularly, so much so that I've now left it off for last, I think this be caused by leaving C1 off during testing?
3 - need to set Max Voltage VR2 to 25V (think this is what you advised for my transformer VA at 3amp?) but can't get it lower than 25.4V - not a major problem probably need to adjust the value of R11?
4 - Can't get the 0V to 0V, lowest is about 0.7V, RV1 seems to make no difference, even without C7 and with a small load.
5 - When Current pot set to min, current limit LED comes on. This is to be corrected by increasing R17 from 33ohm to about 39 to 47 ohm?
Please can you help.
thanks in advance!
