A 22V transformer will allow a 23VDC output at max current. Use a bigger main filter capacitor because the original one is much too small.I have 60VA transformator (230 / 22VAC - 2,8A). Is that enough for original regulated power supply ( here )? How many ampers fuse I need for that transoformator on primar side?
Thanks.
Hello redwire, thanks a lot for this!! I'm looking for this a long time ago ;DHi Corsa, Here is the pcb in EAGLE for the board at the top of the thread. It is a double sided board because I had it produced at a professional shop. It is somewhat of a challenge to build double sided boards at home.
Note that D2 and D3 need to be filled with a 1N4148 and D7 is not used for the latest version.
Good luck
The original circuit uses a 24V/3A transformer. Its max output is about 23VDC at 4.2A but the transformer will be overloaded very much.karthikeid said:hi
what are the things to be checked before connecting the circuit to load...
and i have used only 24volts 3amps transformer what will be the maximum power delivered to the output ???
U3 turns on the LED and makes the output voltage as low as 0V.karthikeid said:my psu seems to be not working there is no voltage variation and i have used tle2141 opamps....what should i do.... ???the led is glowing without any load....
i have posted the circuit diagram and the pcb made by me...
