Circuit requires two voltages for supply
Sadlercomfort
Ash
Feb 9, 2013
424
I'm trying to understand how to build a Royer Oscillator circuit using the LT1172 IC. However this circuit design requires two different voltages, around 6v to supply the IC and around 12v to supply the external part of the circuit.
How could I tap off the main 12v supply, to produce both a 6v and 12v output? I have a few random voltage regulators, and a 100k and 1k potentiometer.
Ash
Which schematic are your using? I don't see that chip needing 2 voltages anywhere, but maybe I am missing one. The input voltage can be up to 60V according to the datasheet. The second voltage listed on the schematics is the output voltage it is producing.
Sadlercomfort
Ash
Feb 9, 2013
424
Here's the schematic, the chip just needs one voltage (preferably a low voltage). The external circuit requires a higher voltage.
14,308
There's nothing in the schematic telling you not to connect pin 5 of the LT1172 to Vin (as long as Vin >3V, which it is).
Sadlercomfort
Ash
Feb 9, 2013
424
Okay, it doesn't say you cant connect them together in the datasheet either.. Just thought I'd check, these chips are expensive.
Ash
