Alex Tsekenis
- Nov 29, 2009
- 299
- Joined
- Nov 29, 2009
- Messages
- 299
Yeah, that is what I meant. Since using a higher volatge trafo will require more parts, in the final project it would be nice to have a trafo that can offer 5A without output ripple.Are you talking about finding a transformer which will allow 0 to 30V @ 5A?
How about arranging for the zener diode regulator across +V+6 and ground by increasing the zener voltage and recalculating the resistance? This will waste more power on the zener (series diodes?) but will allow a 30V trafo and you get a regulated supply for the op-amp.If most people here decide it's a must, then I'll look at redesigning for a 30V transformer. This will probably mean ditching the LDO MOSFET idea and going back to a more traditional transistor based approach.
I have to justify the space they take to myself...
I tried in the past. The problem is that most people buying from ebay can't afford them and those who can, don't buy from ebay if you know what I mean. Might try again in the future.Put them on ebay?
Anything. That is one cheap MOSFET btw..I've decided on the IRLZ34N
Anything than a single 22000uF/63V cap.RS is cheaper for the 10,000μF
Good idea since this is a kit.It's probably a good idea to put footprints on the PCB for two capacitors as well as one and different diameters if convenient.
Can LTSpice do Bode plots? I am asking, I don't know. We can optimise some of the components this way but as you say good enough. We can simulate some reactive loads too later on.I would have thought simulation would be good enough since the simulator performs loop analysis anyway.
Sorry, I get confused with multiple sources on the diagram.Surely it's more cost effective to use one voltage reference IC and obtain other voltage references using potential dividers?
Good thing you rejected that.The original idea was to use an LM78L05 but then I decided the tolerance is too wide.
It is not like we have much choice in TO-92 at this tolerange range... I looked on RS and Farnell, most products are the 431 from different manufacturers :Now I'm thinking of using an LM431B which has a tolerance of 1%. I could use the C version which is 0.5% but it's probably harder to get hold of and will be more expensive.
How about the LM317L? Just an idea. Never mind, the 1.25V bandgap reference is at +/- 0.05 V i.e. 4%.
Fully agree, 5% can also go for R16,17. 1% resistors are used more and more frequently so if we say 1% throughout I dont think the cost difference would be prohibitive, if any. It saves the effort of saying this 5% that 1% etc.I'm thinking 1% for all the gain and reference setting resistors and 5% for everything else.
Close tolerance is nice but <1% starts to get expensive and harder to get hold of.
