Gate Resistors used for IGBT's why? IGBT timing
Danny Daviss
Mar 16, 2013
67
How does the Gate Resistor in series adjust the Timing of a IGBT?
Why does using a small value Gate Resistor resistor cause IGBT to short out? or cause shorts?
A small value Gate resistors changes the IGBT to have faster switching time?
Example:
IGBT drivers to Gate resistors to IGBT to Low Pass filter
The IGBT driver sends High Frequency pulses to the IGBT transistors
What kind of bandwidth an oscilloscope do u need to see these high frequency pulses?
How does the Low pass filter change DC voltage from the output of an IGBT to an AC waveform?
The IGBT output is high Frequency pulses right? and the Low pass filter cause high frequency pulses into an AC waveform?
My oscilloscope is 300MHZ, the IGBT drivers signal is in the killohertz
How can I view Killohertz signals?
14,293
The gate of a MOSFET or an IGBT in your case has a noticeable capacitance. Add a series resistor and you get a low pass filter. YOu can evaluate the math for yourself.
Set the timebase into the ms range. Read the manual, get a thorough understanding of the operations of an oscilloscope,
Danny Daviss
Mar 16, 2013
67
So a 300Mhz oscilloscope can view Kilohertz signals?
I can't view the signals because they are in the kilohertz, it just looks like scramble lines
300Mhz oscilloscope = 300,000 Kilohertz?
Kilohertz is must higher frequency than megahertz right?
14,481
of course :)
your scope may not have a high enough resolution
yes
NO, why would you say that ?? you just proved ( correctly) in your last statement
that MHz is higher than kHz
1 kHz = 1000 Hz
1 MHz = 1,000,000 Hz
14,481
Your scope should have its bandwidth rating up by the brand of the scope
10MHz, 50MHz, 100MHz etc
Danny Daviss
Mar 16, 2013
67
Are IGBT driver chips outputs in the kilohertz? or megahertz?
Where do u find the resolution rating? how high should the o-scope be to view these waveform signals?
Yes the 0-scope i'm using is 300Mhz
Danny Daviss
Mar 16, 2013
67
! I Did, it's my 300mhz o-scope viewing the IGBT Drivers waveforms. The freq is high and the waveform is very close lines together because the freq is so high, is this a resolution problem?
14,481
do you know how to use a scope ? ... specifically how to adj the timebase setting?
you were given a link by some one in another thread of yours on how to use a scope
YOU STILL havent told us anything about your circuit!!
its very difficult to help you when you dont give all the info
You are still following your old ways that you showed on the forum many, many months ago
14,293
My o-scope has an autosetting, autoset button, so it does all the hard work for me
Obviously it doesn't so very well.
Autoranging, autosetting or whatever is good for geeting a first grasp of the Signal. It doesn't replace knowing how to use an oscilloscope, including the limitations. Read the tutorial by Tek (I gave you the link in another thread of yours).
Btw: The "300MHz" Rating for the scope tells you what max. frequency you can Analyse with reasonable accuracy. By no means does this signify that the scope cannot Display much slower waveforms. On the contrary.
The autoset button might give a good first guess, but saying it does all the hard work for you is somewhat like engaging the cruise control on your car and having a nap.
Danny Daviss
Mar 16, 2013
67
Is this correct tho about the IGBT driver datasheets that the IGBT drivers output signal waveform is at 20Khz? at 2us pulse width, 50% duty cycle?
14,293
It can´'t be correct, F=1/T, so with F=20kHz, T=50µs. So either the 20kHz are wrong or the 2µs pulse width.
What are you trying to do? You seem to lack some very basic understanding but you want to work with IGBT drivers. To me thats like trying to drive a race car without knowing how to drive at all.
Danny Daviss
Mar 16, 2013
67
Can you take a look at the IGBT drivers datasheets and tell me what the output frequency is please?
There is no specific output frequency.
And what IGBT driver are you talking about? I can't look at a datasheet without knowing the part number.
