help with IR2110 chips
bertus
3,882
Watch the gate source short on Q1.
Also the powersupply is given as -12 V.
I assume that that should be + 12 Volts.
Bertus
Maglatron
Jul 12, 2023
2,025
thanks mate! how do you add connectors?? sorry yes 12v :) fixed it
need to work out how to put in connectors! also if you can recommend a PCB manufacturer that is good quality and price, that would be great!
Maglatron
Jul 12, 2023
2,025
I want to add a usb female socket (purely for power to the Arduino, and some plug sockets for the output of the inverter, and plug socket for the 12v in, and a socket for the input voltage from the rectified DC from the power coils! I need the USB 3 or 2 female any help guys? purely for power to the Arduino, I'm talking about KiCad
Alec_t
Jul 7, 2015
3,821
You have no drive signals for Hin and Lin.
There should be dead time between the Hin and Lin switching edges to prevent shoot-through, which might otherwise be a problem.
Maglatron
Jul 12, 2023
2,025
yes I realise that's one of the points where I want to put a connector for the Arduino signal pins, leaving dead time of 2us!
Maglatron
Jul 12, 2023
2,025
getting really far with it just need to know how to add connectors, please shed light!!! thanks
Maglatron
Jul 12, 2023
2,025
found it!! 1728401264364.pngwhat do I do here??1728401523696.pngbit of helps guys?!?
Maglatron
Jul 12, 2023
2,025
I want to know how to wire up the circuit using fatter traces for the traces that need to handle more current!
  • INVERTER - Copy.kicad_pcb.txt
Maglatron
Jul 12, 2023
2,025
could someone have a go at wiring it up please finding it really difficult!!!! would be so so so appreciated!!
Maglatron
Jul 12, 2023
2,025
oh well, never mind, could you point out on this diagram which traces need to be thicker and which can be thin please how thick as well please1728414535432.png
Maglatron
Jul 12, 2023
2,025
could you highlight what needs thicker tracks please and which one I can get away with being thin please, I'm on that part now!
Maglatron
Jul 12, 2023
2,025
@ Alec_t perhaps you should get in to it, it is very good!! still stuck though!!
Maglatron
Jul 12, 2023
2,025
this is now correct with the added inverter input! could you highlight the tracks that need to be able to handle the higher currents1728417897127.png
bertus
3,882
I would say all power carrying lines shoud be wider.
So the in and output lines of the inverter, the drain and source lines of the mosfets and the ground lines for the mosfets.
Bertus
