help with IR2110 chips
Use the EasyEDA software and get a direct quote from JLCPCB .....couldn't be simpler.
$2 for 5 boards (100mm x100mm)max
Just watch postage
I usually select the cheapest which takes around 10 days to Aus. $1.50 last lot.
Can be $50 if you don't watch out for it and change it.
[mod edit] changed the formatting as two $ signs within one line are automatically interpreted as an indicator to enter inline math mode. This doesn't happen when the dollar signs are on separate lines.
Maglatron
Jul 12, 2023
2,025
Just watch postage
I usually select the cheapest which takes around 10 days to Aus $1.50 last lot.
Is easyEDA free??
Maglatron
Jul 12, 2023
2,025
cool could someone get me an activation file because I can't access email at the moment!!
Maglatron
Jul 12, 2023
2,025
if not I will hopefully get a chance to do it tonight!!
can someone get the file please??
Maglatron
Jul 12, 2023
2,025
anyone??? it is okay now I have done it!!
Maglatron
Jul 12, 2023
2,025
does it have an auto router for dual sides?
Maglatron
Jul 12, 2023
2,025
I want to get going with this but struggling with the basics!!
got it to look the same now had to choose student version!
ok now I am getting to grips with it, nice software!!! thanks guys
Maglatron
Jul 12, 2023
2,025
Maglatron
Jul 12, 2023
2,025
how do you save the schematic to a file to upload there are a couple of things wrong with it!
Maglatron
Jul 12, 2023
2,025
how do you save the schematic to a file to upload there are a couple of things wrong with it I got the .json file hope you guys can help!! if you guys need anything else just let me know please please please can you help me get this working!!
  • SCH_INVERTER_2024-10-10 - Copy.json.txt
Maglatron
Jul 12, 2023
2,025
it says something about nets is this important? or can I just click "no keep going"
Maglatron
Jul 12, 2023
2,025
can't get the resistors to be the normal size through hole 6mm or more please help!! I keep getting smd pads!! I need through hole resistors
I have tried multiple times now and I am getting quite frustrated really! please help guys1728640553771.png
Is easyEDA free??
Yes.
When finished your layout you can submit it to JLCPCB for their checking.
Naturally there are design rule checks you can set when you do the "generate PCB".
After that you can ask for a price, watching your delivery options as I mentioned previously.
As with anything, you have to learn how to use the software.
It is NOT just open up and work.
I had to learn so you can as well without thinking you can jump straight in to the deep end.
Hint on resistors, it depends on what size and type you select in the common library.
Maglatron
Jul 12, 2023
2,025
thanks Bluejets I have worked out the resistors now I need to find out how to make the diodes 18mm from leg to leg!! any tips?
Use an appropriate size diode from the library. Perhaps just put vias/pads of whatever spacing and size.
Maglatron
Jul 12, 2023
2,025
1728659288384.pngthis corresponds to this!
1728659478595.pngI want the fat blue lines to be thicker traces1728659858619.png
