LED Circuit for Electric Fence Light
Crashtest007
Mar 3, 2024
Hi All,
I am new here , and to Electronics so plese go gentle on me! :)
I have a Circuit Diagram that I have created in Adobe Illustrator to hopefully Show what I have so far.
I found an OLD Fence Light. The Light looks as though it has been run over. I am trying to "Back Engineer" the Light and made this Diagram.
Anyway! I would like to Build this myself and have a "Basic" knowledge of electronics. I haven't built this YET and would like to know if this Circuit would WORK.
You basically hang the + Positive lead on the "Hotwire" of the Fence and connect the - Neg to earth wire / post on the electric fence. It draws the power from the fence pulses itself, so no batteries are required.
Thanks for your help in Advance !
Wayne
Martaine2005
May 12, 2015
5,318
Use an old sparkplug.
I think OP wants visual of pulses and not to just check the fence.
To check the fence is working, simply wee on it. Only hurts for a minute:)
Your circuit should work although you might want a heftier diode depending on fence voltage.
Crashtest007
Mar 3, 2024
That IS Correct! Visual Pulses. I have checked the Fence many times with a jolt to the arm or Head. So all references to holding to check if woking will fall on Deaf Ears. There's Always one ;) and that's usually me... Ha Ha Ha
I did realise that.
One we used could see over 1/2 mile away at night.
No need to piss on it either as a blade of grass will give a decent indication.
danadak
Feb 19, 2021
1,104
Electric fence V, at only leakage levels, in the 10 kV range. If you
load it with LED kinds of current the fence operating V will drop
significantly.
A cheap HV diode could be microwave oven diode like :
You also have a problem with resistors that can withstand HV w/op arcing, so use ones with lead
distance that can prevent arcing :
Or you could use a HV cap........
You will also want to coat the circuit to prevent moisture/humidity type arcing,
silicon rubber (not sure it can handle V, chk this out).
The value of the R experiment with, maybe start with something like 100 uA
current for the LEDs......I think if you attempt in mA range would compromise
fence effectiveness.
Regards, Dana.
crutschow
May 7, 2021
991
I recommend using real neon lamps or tubes in series with a high resistance for the indication.
The current LEDs require to light will likely kill the fencer voltage.
