new DAB pocket radio story
W
Whiskers
Yup. And of course *if* DAB+ comes along, the two will run side by side
for a long time. Probably 10 years.
The BBC started VHF/FM broadcasting in 1955; AM hasn't vanished yet, and
the Beeb were still broadcasting their three main stations nationally on
both AM and FM until quite recently (I forget when they dropped the MW
versions of Radio 2 Radio 3 and Radio 4 - Radio 4 is still on LW nationally
and MW in a few areas, and the World Service and Five Live are still on MW
nationally). I doubt if DAB will run in parallel with another system for
50 years, though!
It remains to be seen whether Britain will attempt to have DAB and DAB+ at
the same time, or whether the existing MW and/or FM bands will be
digitalised instead (DRM and DRM+ respectively), or as well - France
seems to be going for DRM. So will we still be able to use the oldest
receivers when they hit their 100th birthdays? We may know a little
better when the govt working party report soon.
W
Whiskers
Roberts Stream 202 Wi-Fi radio with DAB is DAB+ upgradeable as well,
and I think there's one or two more battery-powered portable radios
that are DAB+ upgradeable..
OK, so there is some movement in the directiom you want :))
Here we go - I can feel an out-of-his-depth gob-off coming.
Don't feel too bad about it, I'm getting used to your obsession now. My
own obsessions are different, but an be just as inhibiting when they
intrude.
DAB was relaunched in the UK in 2002. AAC was standardised in 1997.
Don't try to suggest that they didn't have more than enough time to
upgrade DAB prior to relaunching it.
Yes, of course, it's blindingly obvious to anyone with half a brain that
Ofcom should have insisted in 2002 (having failed to do so in 1980) that
all digital radio broadcasts in the UK should henceforth be made to a
standard that was going to come into existence in 2006, with the first
commercial receivers not being on the market till 2007.
Such lack of hindsight before the event is quite appalling.
(AAC is not DAB+; one is a codec, the other is a radio broadcast standard).
If you don't understand what went on, why do you try to sound like you
do know what you're talking about? Here's the lowdown on what
happened:
<Yawn>
DAB sounds worse than FM
that
that
a
first
I did ask you to read this:
http://www.digitalradiotech.co.uk/dab/incompetent_adoption_of_dab.htm
But you clearly haven't bothered, so I'll briefly explain why you're
wrong.
AAC was standardised in 1997. DAB was re-launched in 2002. That's a
5-year gap, so don't try to make out that the UK DAB people couldn't
have upgraded DAB in that 5-year period. If you release a new
broadcast radio system, it's meant to last a long time, so you have to
get the design right before you launch it. But they launched an
incredibly inefficient system, and its inefficiency also makes it
extremely expensive to transmit, which is something that is still
plaguing the system today, because Channel 4 wouldn't have had to drop
out if the transmission costs had been lower, and the national
stations that closed down earlier this year were all due to the sky
high transmission costs.
On the day that the BBC dropped its bit rates, which if I remember
correctly was on 18th or 21st December 2001, in the first couple of
posts on the first thread about the BBC slashing their bit rates
someone said that they should have used AAC, and that MP2 was not
designed to be used at such low bit rates as 128 kbps.
So it is not me taking advantage of hindsight. The BBC screwed things
up completely. That's all there is to it. Basically, the non-technical
BBC execs simply over-ruled the engineers. For example, here's a
brochure for a BBC R&D open day in 1999:
http://www.digitalradiotech.co.uk/documents/BBC_R&D_AAC_1999_Open_Day.pdf
and at the top it says:
"New audio coding systems (such as AAC) can halve the bit-rate"
"Don't squeeze the bit-rate"
The BBC R&D department had also taken part in 2 listening tests that
compared AAC with MP2 in 1996 and 1998, and both of those tests had
confirmed that AAC was twice as efficient as MP2 (see links to these
listening tests on my page about the incompetent adoption of DAB),
hence why they said what they did about AAC above.
When non-technical execs make technical decisions at the BBC, they
first take advice from the experts in R&D. So they will have heard
what the R&D people were saying about AAC vs MP2, but they must have
simply ignored them.
The BBC had been saying since the early 1990s that they were going to
launch new radio stations on DAB, and by 1998 they were already saying
they were going to launch 4 new stations:
http://news.bbc.co.uk/1/hi/entertainment/174535.stm
That's in addition to Radios 1-5 and the World Service. They could
have realised that the audio quality would be crap on DAB at any point
from when they first said they were going to launch a load of new
stations on DAB. But they didn't, and here we are.
So don't try to make out that I'm only saying this with the benefit of
hindsight.
standard).
Don't try to lecture me about what DAB+ is. DAB+ was basically my
idea. I was by far the first to point out on my website just how much
more efficient (6x and 4x for DVB-H and DMB respectively) and
therefore how much cheaper for the broadcasters the mobile TV systems
were for carrying radio than DAB is, because they use AAC (and later
AAC+) and stronger error correction. And DAB+ is simply the DMB mobile
TV system but without the video. See:
http://www.digitalradiotech.co.uk/dvb-h_dab_dmb.htm#DMB_Should_Replace_DAB
Steve - www.digitalradiotech.co.uk - Digital Radio News & Info
The adoption of DAB was the most incompetent technical
decision ever made in the history of UK broadcasting:
W
Whiskers
The usual rubbish. Stations close - or fail to open - because they can't
generate the income to cover their operating costs, wherever these arise
from.
Of course it's expensive to transmit. It's called market forces.
Otherwise you just have a free for all.
The stations that have so far failed have been broadcasting stuff that
doesn't attract enough of an audience to generate the sort of advertising
revenue needed to keep the thing solvent. Nothing to do with technology.
Channel 4 are struggling to keep going on their one TV channel; that's why
they can't afford to splurge on new radio stations.
can't
4 national stations closed on the Digital One multiplex earlier this
year because they couldn't afford to pay the £1 million per year
transmission costs.
DAB+ is 2 - 3 times cheaper to transmit per station. That's a big, big
saving for a station.
from.
What an utterly ridiculous statement.
that
advertising
Digital One is only carrying one station - Planet Rock - that isn't
already a big station on FM/AM. Why? Because the transmission cost for
a stereo station is £1 million per year.
Nothing to do with technology? Transmission costs on DAB are as high
as they are precisely because the technology is very inefficient.
Can you not understand that the FIXED multiplex transmission costs
being shared by say 30 stations is gonig to lead to lower transmission
costs than if they're shared between 10 stations?
that's why
Correct. That's the only correct thing you've said for some time now.
That will be why FM costs are lower then...
FM is totally irrelevant. You just say things for the sake of it,
don't you. You put absolutely no thought in to whatever you say, and
you just go straight for the gob off.
The costs charged for rental have little to do with actual costs.
Totally wrong. It was the TRANSMISSION COSTS that caused the DAB
crisis earlier this year. GCap wanted to close 4 stations (theJazz,
Core, Life and Planet Rock - the latter was sold), and it wanted to
sell its 67% stake in Digital One for £1 to Arqiva.
It was the transmission costs that led to that and to Fru Hazlitt
saying that DAB is "not an economically viable platform".
It's common knowledge that the transmission costs are exhorbitant on
DAB.
W
Whiskers
Yup. There are already more than can make a reasonable income from the
advertising pot that exists. So a new one has either to expand that pot or
pinch from others.
I think they also found out - rather late - the costs of trying to
provide the sort of speech based progs they promised.
It's all too easy to find people who will talk ceaselessly for no money at
all - but finding people who can talk and have other people want to
listen, is a whole other kettle of ballgames.
Using a different audio codec to squeeze twice as many stations onto the
same transmitter, just means you'll have to find twice as much talent as
the existing stations haven't. So you get twice as many failed efforts and
twice as many unpaid bills - and twice as much unused transmitter capacity.
Even if there are people out there with equipment that can actually handle
the new codec.
W
Whiskers
transmission costs.
They couldn't afford the transmitter costs because they failed to provide
content that people would listen to in large enough numbers to attract
advertisers to pay the bills.
Only if you can find 2 - 3 times as many people to set up stations and
provide stuff people want to listen to. If four companies have failed to
manage that, what makes you think eight to twelve companies could?
Multiplying the number of stations is easy; multiplying the amount of
talent to make good use of them is very very difficult, and multiplying
the number of listeners is in a different realm entirely.
the
talent as
efforts
and twice as many unpaid bills - and twice as much unused
transmitter
capacity. Even if there are people out there with equipment that can
actually handle the new codec.
DAB+ wouldn't launch yet anyway, because there aren't enough receivers
out there.
But the economics are vastly superior on DAB+ than on DAB. The
transmission costs per station are 2-3 times lower than on DAB. It
also makes it cost effective to provide much better quality.
DAB+ is an inevitability.
H
hwh
No. It means that you only need one multiplex to transmit the same
number of stations that were previously on two of them.
gr, hwh
Not so. You give the impression transmissions fees bear some
relation to
the actual costs. You're wrong.
Digital One charges over £1m per annum to carry a stereo station. So
how much would you say the transmission costs would be for Digital
One?
Absolutely. The idea of the 'big brother' channel providing serious
competition to R4 is a joke. In the early days of CH4 I might have
believed it.
C4 were going to launch 3 new stations: E4 Radio, which would have had
Big Brother programmes on it, plus Channel 4 Radio, whcih was meant to
compete with R4, adn Pure4, which was a bit like 6 Music with more
talk.
Indeed. Our hyper 'DAB' friend seems to think the transmitter rental
is
based on how much electricity it uses.
Oh, that couldn't be further from the truth. How much do you think it
would cost to transmit Digital One?
My view is there'll be great resistance to replacing relatively new
equipment *if* they use the new standard. Portable radios don't
really fit
into the 'must have the latest' scenario. And the numbers who won't
use
the current DAB because of the quality are tiny.
I've explained this elsewhere. If you're too stupid to understand what
I've said, I can't be arsed repeating it again.
provide
attract
Thanks for stating the bleeding obvious.
big
and
Not so. You're assuming that DAB+ could only be launched on new
multiplexes. But DAB+ stations could fit onto existing multiplexes,
and DAB and DAB+ stations only pay for the capacity they use, and
that's why DAB+ stations are 2-3 times cheaper to transmit, because
they use 2-3 times less capacity.
A good example is that a DAB+ station could fit onto what is a "full"
multiplex in terms of there being insufficient spare capacity to carry
another DAB stereo station. So DAB+ stations could be launched in the
most lucrative radio markets, such as London, when DAB stations
coudln't be launched because there's not enough capacity.
Also, if a broadcaster currently has capacity on a London multiplex,
once there's a sufficiently high number of DAB+ receivers in the
market it could withdraw one station and replace it with the same
station but in DAB+ and launch one or two new stations alongside it to
make extra money.
Basically, leave DAB+ to people who know about it, there's a good boy.
There are 7.7m DAB receivers sold so far. There are 120m - 150m FM
devices in-use according to Ofcom. So the advertising pot for DAB will
obviously increase over time, so all your nonsense, or maybe Plowman's
nonsense, about the advertising pot being a fixed size on DAB, is
obviously just nonsense.
of
multiplying
See above re ownership.
FFS. Transmitter rental is a figure plucked out of the air - based
on what
'they' think the market can stand. There's absolutely no reason to
believe
a more efficient transmission method will alter this.
Bullshit. The multiplex transmission costs are already known (and
contracts have been signed), and the transmitter networks don't need
to change at all to carry DAB+, so the transmission providers can't
turn round and just increase costs. The broadcasters all know this, so
the multiplex operators (which are all owned by the broadcasters
anyway) can hardly just bump the price up.
See:
http://www.worlddab.org/public_documents/dab_plus_brochure_200803.pdf
"The benefits of DAB+ include:
Lower transmission costs for digital stations"
W
Whiskers
See:
Page 4 of 12:
WorldDMB created a Task Force of its Technical Committee to develop the
additional standard. After examining the options, DAB+ using MPEG-4
HEAAC v2 was adopted. DAB+ was published in February 2007 as ETSI TS
102 563 “Digital Audio Broadcasting (DAB);Transport of Advanced Audio
Coding (AAC) audioâ€.
Which could just be a clue as to why Ofcom didn't insist on DAB+ being
immplemented five years earlier. Don't you think?
Page 8 (Graphics omitted, for obvious reasons):
Possible scenarios with DAB+
The following figures show how the bit rate of a DAB ensemble may be
assigned to:
Multiplex with MPEG Audio Layer II (DAB)
9 radio services using MPEG Audio Layer II at 128 kbps
Multiplex with HE-AAC v2 (DAB+)
28 radio services using HE-AAC v2 at 40 kbps and 1
audio service using HE-AAC v2 at 32 kbps.
Multiplex with MPEG Audio Layer II and HE-AAC v2 (DAB and DAB+)
5 radio services using MPEG Audio Layer II at 128 kbps
and 12 radio services using HE-AAC v2 at 40 kbps and
1 radio service using HE-AAC v2 at 32 kbps
A 40 kbps subchannel with HE-AAC v2 provides a similar audio quality
(even slightly better in most cases) to MPEG Audio Layer II at 128
kbps.
Technology is the easy bit, content is the hard part.
need
so
See:
Page 4 of 12:
develop the
MPEG-4
TS
Audio
being
You must just ignore anything that you don't want to know. I've
already explained what happened in a reply to you once today. That was
a long post, so I'm not going to fucking rewrite it all for some moron
who will deliberately choose not to believe me anyway.
Here's the contents of the post you chose not to read earlier today:
wrong.
hindsight.
standard).
be
assigned to:
quality
128
kbps.
If technology was the easy bit, why did the BBC et al adopt DAB? The
adoption of DAB was grossly incompetent.
tony sayer
Who do the actual transmission.
And I reckon before long will become a large broadcaster in their own
right..
Then all the commercial broadcast and transmission platforms will be
Aussie controlled;(...
DAB.
Indeed couldn't be better set up for a Monopoly organisation;!...
