No. Transistors can be used as switches many other ways.vivek_pv said:Is this the only way to create?
Yes. You can add a 2nd transistor to make your own darlington transistor or buy a darlington transistor. Then the 100k resistor consumes very little current. See my modified schematicis there any other way so that battery power is saved? (When this switched is closed, the 3.3k will consume some little current)
No. It is a transistor inverting switch. A digital inverter inverts a digital voltage level or pulse.View attachment 39490Is this model called a "digital inverter"
Perhaps this drawing makes it more clear?vivek_pv said:Dears,
Which transistor/s should be used (how?) for creating a "not-gate"?
And what should be the arrangement in order to cut-off the circuit if there is a specific signal? (using not-gate)
Vivek v
