Jim Thompson
- Jan 1, 1970
- 0
Joerg skrev:Jim said:On Sat, 20 Jan 2007 15:04:40 -0700, Jim Thompson
On Sat, 20 Jan 2007 13:53:14 -0800, David R Brooks
[snip]
Imho, that just about proves it. Those old laptops did have much meatier
power supplies. If you trawl the specs, you'll likely find the old ones
had RS232C, while the new one is RS232E. That's exactly the difference:
12V vs. about 6V, while the intended receiver load has reduced by an
order of magnitude. Since RS232 defines anything over 3V as a valid
signal, the interface-chip makers consider themselves free to provide
just enough power to stagger over the line, & they are in compliance.
Aha! Which says the solution is to provide 12V power to the
track-ball and add some 1488's and 1489's to buffer the levels ;-)
Or, as Joerg would do it... discretes ;-)
A micro would be a suck solution ;-)
...Jim Thompson
Joerg allowed as to how he'd already run serial data thru the port.
What were the levels?
Ok, guys, thanks for that hint about the voltage levels. Whipped out the
meter: It's 5.9V. Dang! Why on earth did they do that?
rs232 tranceiver with voltage doubler running of 3Volt, I guess
Jim, I am indeed itching to see if a discrete solution sans external 12V
supply could be done. Just for sports. Maybe one of those one transistor
switchers, a few turns around a ferrite bead, hmm....
old fashion rs232 transceiver back to back, running of 5volt taken form
USB or PS2 port?
-Lasse
I think the problem is that the track-ball needs 12V, so you need an
interface:
(laptop) 6V data <=> 12V data (track-ball with 12VDC supply)
Joerg needs to measure what RS232 levels exist on his new laptop, then
measure the trackball levels with one of his old machines.
Then we can concoct an interface with a snap of the fingers.
Of course this episode has already cost Joerg $1K in wasted time spent
scratching his ... ;-)
...Jim Thompson
