Pioneer PDM450 laser help
  • Thread starter Gary L. Woodruff
  • Start date
Gary L. Woodruff
howdy, I have a pioneer PD-M450 Cd player that would not play disks. It
would load them but and the laser would go in try to focus but the disk
would never spin. I found the plastic lens had fallen out of the optical
assembly and would not stay in when replaced. I ordered a new optical
pickup and replaced the old one. I have the same problem. I have
confirmed that the spindle motor will run with 1.0 vdc supplied. I do
not see any voltage appear at the motor leads while the lens is trying
to focus. Please help, optical pickup was $$$$.
thanks, Gary
Sam Goldwasser
Andy Cuffe said:
I have heard that you can glue the lens back in, but I've never had
one to try that with. The new optical pickup probably needs a
complete alignment. You'll need the service manual, oscilloscope, and
other test equipment.
I've glued the lenses back a couple of times. Use 5 minute Epoxy, NOT
superglue. Just make sure it seats as far as it will (gently) go.
I was impressed how easily this could be done on something that has to
focus to a couple microns! :)
sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
David Farber
It would load them but and the laser would go in try to focus but the
disk would never spin. I found the plastic lens had fallen out of the
optical assembly and would not stay in when replaced. I ordered a new
optical pickup and replaced the old one. I have the same problem. I
have confirmed that the spindle motor will run with 1.0 vdc supplied.
I do not see any voltage appear at the motor leads while the lens is
trying to focus. Please help, optical pickup was $$$$.
thanks, Gary
The replacement pickup may not work right out of the box because IIRC, it
doesn't come pre-aligned. You'll need to boot it into test mode and use a
scope probe to adjust it. I believe it's called the gradient adjustment.
Might just be easier to do as the previous responders have suggested which
is to carefully glue the lens back on. Make sure whatever glue you use, that
it doesn't fog up the lens!
