Moojundai
- Jan 1, 1970
- 0
I've been handed a projekt to solve if possible, and I'd love some feedback
from you folks to see if youre experience could help me on the way.
Problem:
A small highly insulated outhouse needs to be keept frost free in short
bursts of up to 15 degrees of frost.
The system must if possible be made by 12v renewable energy alone.
Existing parts:
1) Rutland 915 wind generator (200W)
I thought about mounting the wind generator on a 8 metre pole beside the
outhouse, connected to a deep cycle battery inside the outhouse.
How to build a 12V heat souce that doesn't use to much power (W)?
My idea was to use a series of 20-55W bulbs to create heat in a insulated
box, and create a draught by mounting a small ventilator from a computer
(cooler from a processor or power supply unit).
This system would be powered through a "powerguard", that would "cut" the
power before the battery is empty, as I expect running the system at <9V
would not do much good, and that it's better to conserve power a bit than
run the system into the ground (0V) where the bulbs only would glow a bit
without giving heat.
Would it be best to dig holed tubes into some sand, and let the warm air
seep throu the sand, and let the sand keep the temperature for longer time
than the air alone?
I hope to get some feedback from you guys!
Problem:
Existing parts:
than the air alone?
