What is the resistance and wattage of this resistor
Rayregula
Dec 20, 2016
84
It's very hard to tell. But if you have a multimeter you can determine the resistance easily.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,980
Yes, go to a "big box" home improvement store or even Radio Shack and purchase an inexpensive digital multimeter. If you are serious about electronics you can "upgrade" to a more capable multimeter later. Expect to spend about twenty bux to get started.
BTW, those solder-less breadboards you show in your excellent photos are designed to accept component wires in the range of 22 to 24 AWG sizes. Shoving power resistor leads into them will damage the spring contacts inside and result in unreliable connections when you try to use those holes again with "normal size" component leads. Don't ask me how I know this.
sundy
Aug 5, 2016
64
Is it a resistor? I suppose it could be an inductor since it is not marked as a resistor usually is. But it's not marked like an inductor either!
Rayregula
Dec 20, 2016
84
"BTW, those solder-less breadboards you show in your excellent photos are designed to accept component wires in the range of 22 to 24 AWG sizes. Shoving power resistor leads into them will damage the spring contacts inside and result in unreliable connections when you try to use those holes again with "normal size" component leads. Don't ask me how I know this.
I just balanced it on top, don't want to hurt my breadboard :)
cjdelphi
Oct 26, 2011
1,166
Wattage depends on size, that looks like a 1 to 3watt (5watt and higher usually come in ceramic)
