Jump to content
Electronics-Lab.com Community
555 timer help
i have attached a what i think is a 120off / 1 sec on
Can someone check it over and tell me if its ok.
Also is it possible to make it 10 mins off 2sec on, and i need to put a reed switch on it somewhere to turn it on when switches are on.
Also with the 120off/1on will it reset back to 120 after the on state.
Link to comment
Share on other sites
Hi Suraj,
The 555 is a dedicated timer IC. The problem that it has with long time periods is that the timing capacitor must have a high accurate value. Electrolytic caps are not accurate and they have a fairly high leakage current.
If you are rich and have lotsa space, you could use 100 or more 1uF 5% tolerance caps in parallel!
For years I have been using the CD4060 oscillator/counter IC for long time delays, using a cheap low-value accurate timing cap. I have recently discovered the CD4541 that is much better than the CD4060 because it has a longer divider, built-in powerup reset and a choice of output polarity. It is smaller too (14 pins),
http://www.microcontrolador.com.br/datasheets/CD4541.pdf
Link to comment
Hi Stuee,
Never mind the Instant Messaging, let's let everyone see how easy it is to make a long duration timer with the CD4541.
Here is a 5 minute timer where the output goes low after the time period (it can be made to go high if you want). Change the cap for a different time period. Add an RC network and a Schmitt trigger, or another timer to get a 2 second pulse. I got this one from the 1st page of about 77 pages about it on a google search:
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
