Diarmuid Posted March 28, 2006 Report Posted March 28, 2006 On an audio circuit I am copying, there are a lot of resistors with just one line, a black one in the centre. As in the colour code, black is 0 are all these resistors likely to be 0 ohms and thus can I just replace them with normal wire?Thanks for your helpDiarmuid Quote
logan_dslasher Posted March 29, 2006 Report Posted March 29, 2006 huh!?! i never knew that! :) and i definitely haven't seen one.. so, they are just simply, JUMPERS! duh?! why would anyone want to manufacture them? what is their importance? Quote
ante Posted March 29, 2006 Report Posted March 29, 2006 Hi logan,The machines which put together the pcb:s can recognize a dummy resistor but not a piece of bare wire. Quote
audioguru Posted March 29, 2006 Report Posted March 29, 2006 Hi Logan,The "zero ohm" jumpers are the same physical shape as a resistor so therefore are able to be handled and placed on a pcb by automated machines that install resistors on pcbs.Same idea as Ante. Quote
logan_dslasher Posted March 30, 2006 Report Posted March 30, 2006 ahh... so that's what they are for... thanks :) for the explanation, both of you.. 8) Quote
hotwaterwizard Posted April 23, 2006 Report Posted April 23, 2006 Also sometimes a regular jumper will ark and a wire will melt off the insullation under heavy load conditions. Quote
indulis Posted April 23, 2006 Report Posted April 23, 2006 Typically they are used as jumpers on PCB's when cost has to be cheap, as in single sided or no thru plated holes. To put "ampacity" into perspective, it takes 10 amps to fuse a 30AWG wire. Quote
prateeksikka Posted May 4, 2006 Report Posted May 4, 2006 hi....10 jumbers v/s 10 resistors....where goes the cost of the system.well do u people say that these are used in automated systems which manufacture the PCBs by soldering the components?thanks for reply in advance Quote
