esil Posted August 2, 2006 Report Share Posted August 2, 2006 24V AC is a standard Voltage Output of common transformers, that's why this circuit was designed for this voltage. A few volts up or down(maybe +-5V) aren't going to produce any fault but it is recommended that you use a 24V AC transformer. ID:[email protected] Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 2, 2006 Report Share Posted August 2, 2006 Hi Esil,Welcome to our forum. ;DPeople have made the original project and report that the max output is only about 25VDC at about 2.5A. I made a list of the circuit's voltage losses to show why.The transformer's voltage rating is too low for the project to have a well regulated output of 30VDC at 3A. Even with a 24VAC transformer, when the load current is low then two of the opamps have a total supply voltage that is much higher than their absolute max rating of 36VDC. Therefore opamps with a higher supply voltage rating are needed anyway.Transformer manufacturers make transformers with many different output voltages and the 30VAC that I recommend for this project is one. Quote Link to comment Share on other sites More sharing options...
sophos.pl Posted August 17, 2006 Report Share Posted August 17, 2006 Hi, can anybody help me ?I have problem with current limiter, when I short output current limiter is works but led dont lights, when I normaly work on this power supply and i want set current limit with P2 led imediatly light and Output voltage is 0V.sorry for my english.. Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 17, 2006 Report Share Posted August 17, 2006 Opamp U3 is used for current regulation. It compares the voltage across R7 (which is caused by load current) to the voltage of the current adjustment pot P2. Its pin 4 must be about -5.6V or it won't work correctly. Quote Link to comment Share on other sites More sharing options...
sophos.pl Posted August 17, 2006 Report Share Posted August 17, 2006 Thanks for replyvoltage in pin 4 is ok -5.5Vproblem is that when i turn P2 only little curent limiter is start and v out =0 Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 17, 2006 Report Share Posted August 17, 2006 voltage in pin 4 is ok -5.5Vproblem is that when i turn P2 only little curent limiter is start and v out =0Then R21 connects to the wrong end of R7. Quote Link to comment Share on other sites More sharing options...
sophos.pl Posted August 17, 2006 Report Share Posted August 17, 2006 r21 is in correct place.Short history of my problem :When i start power supply first time everything was ok. current limiter worked etc... but when i short circuit output then q4 burned, i replace q4 with new 2n3055 and q2 with bd243. Now when i short output curent limiter work v out = 0v but led dont light. In normal operation current limit is work "too good" :) when i turn P2 only little led light and v =0v Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 17, 2006 Report Share Posted August 17, 2006 U3 is supposed to compare the voltage across R7 caused by the load's current, with the voltage from P2 which is from nearly nothing to 1.7V.With P2 at max and the voltage from P2 at 1.7V then U3 does nothing until the voltage across R7 is slightly more than 1.7V which would be caused by a load current of 1.7V/0.47= 3.6A. If P2 is set to half then the load current must exceed 1.8A for U3 to begin reducing the output voltage.Q3 conducts and turns on the LED whenever the output of U3 drops to begin reducing the output voltage.Maybe your R7 has also burned and is now a much higher value. Quote Link to comment Share on other sites More sharing options...
rufinus Posted September 6, 2006 Report Share Posted September 6, 2006 Hi everyone!I just finished reading this threads about 0-30v power supply (both original and 5 amp mod). About 100 pages... 2 days time.. WowSo, i desided to build it, namely the Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 6, 2006 Report Share Posted September 6, 2006 Hi Rufinus,Welcome to our forum. ;DIt must be a big transformer. Use one of the 24V/5A windings, it is probably 48V with a center-tap. Insulate the other 24V wire.The voltage adjustment for your project will try to make the output exceed 24V and then settings higher will be full of ripple. Maybe you should add a resistor in series with the voltage adjustment pot to limit the max output voltage to a little lower than where the ripple becomes noticeable with full load. Quote Link to comment Share on other sites More sharing options...
rufinus Posted September 6, 2006 Report Share Posted September 6, 2006 And here comes Audioguru! Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 6, 2006 Report Share Posted September 6, 2006 Now, i remember few pages ago you posted new version of mod with 2 trimpots for V/C limiting, i guess i should use that one?Adding both trimpots is a good idea. I forgot that the current adjustment pot will try to make a max current of 4A which is way too high. Parts list stays the same ( 0-30V Mod parts list)? Quote Link to comment Share on other sites More sharing options...
rufinus Posted September 6, 2006 Report Share Posted September 6, 2006 So far, so good!Many thanx again. Off i go to produce PCB and collect the rest of the parts.BTW, Eagle PCB , posted on previous pages, does not work :(My Eagle Light says it was made with some faulty version of Eagle ;)"Load error 283... blah blah blah.." Quote Link to comment Share on other sites More sharing options...
rufinus Posted September 6, 2006 Report Share Posted September 6, 2006 Went for a walk and had an idea. Surely i want to have an volt/ammeter built in.Digital one. One way is to buy standard models such as 7021 based. I thought of making one myself. I have spare PIC16F870 which has four 10 bit A/D converters on board. And i just bougt two 2x16 LCD screens on ebay. The question is, how to make multimeter out of this. Software for conversion i can write, but how to interface 0-24 volts to 0-5 volts of PIC? Hardware is my weak point :(Besides simple multimeter it is possible to output other info on screen too, such as how mant watt load is consuming, temperatures of power transistors, control of the cooling fan... Any ideas will be appreciated. In the case of success i could share a firmware for PIC here on forum. If anyone interested.... Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 6, 2006 Report Share Posted September 6, 2006 An LCD voltmeter, ammeter project has already been done and was posted in our Projects Section only a few days ago.http://www.electronics-lab.com/projects/test/022/index.html Quote Link to comment Share on other sites More sharing options...
rufinus Posted September 6, 2006 Report Share Posted September 6, 2006 Yes, thank you, audioguru, but i already saw it. It is based on a chip from Atmel plus it is a surface mount version of chip, which will be difficult to mount for beginners. I work with PICs and program in PicBasic.There is no sourse code for development and in general schematics and project are not very clear, at least for me. Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 6, 2006 Report Share Posted September 6, 2006 I would just buy two LCD voltmeter modules and add resistors for them to display voltage and current. The current meter should measure the voltage across R7 which indicates the current without reducing the output voltage. Quote Link to comment Share on other sites More sharing options...
rufinus Posted September 6, 2006 Report Share Posted September 6, 2006 I just sampled some TC7107 from Microchip ;)I have some spare LED 7-segment displays, so i will try them first. But i still like the idea with PIC 8) Quote Link to comment Share on other sites More sharing options...
spy_id Posted September 13, 2006 Report Share Posted September 13, 2006 GuysYou have been awesome supporting this project. I have built this PSU (see attached) but need some help!I have a step-down transformer with 2x75VA secondary windings. If I connect them in series I get 34.0v AC and 52.0v rectified. This I think is too much for the OPA445s, in fact I know it is because 2 of them blew up after I connected it ;DAs a test for the circuit, I disconnected one of the secondary windings and replaced my dead OPA445s with 60p TL081s. With P1 cranked up, I measured [email protected] across pins 3 and 4 8)With the 2 windings connected, the reference voltage is ok - 5.6v appearing across D8 - and 11.v at pin 6 of U1. U2 is not happy though, he gets an input voltage at pin 3 proportional to P1's setting but nothing at pin 6.What's my best bet? Upgrade R1? If so, what to?Thanks fellasspy Quote Link to comment Share on other sites More sharing options...
roujhan Posted September 13, 2006 Report Share Posted September 13, 2006 Hello All.I am new to electronics, can anybody help me about some questions?!First i want to know how the voltage in output of U1 gradually increases till D8 turn on?And my second question is about the current limiter; in fact i read the explanations but i wonder if some body explain more about how it work...I'm sorry for my stupidily questions...Many thanks, Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 13, 2006 Report Share Posted September 13, 2006 I have a step-down transformer with 2x75VA secondary windings. If I connect them in series I get 34.0v AC and 52.0v rectified.52VDC is much too high for many parts of the circuit.This I think is too much for the OPA445s, in fact I know it is because 2 of them blew up after I connected itThe OPA445 has an absolute max supply voltage of 100V. The factory tests them at 80V. Your circuit gave them a total supply of only 52V + 5.6V= 57.6V but had them dissipate too much heat and they melted. The heat is caused by the supply voltage times their output current.U2 is not happy though, he gets an input voltage at pin 3 proportional to P1's setting but nothing at pin 6.Then either U2 is broken or its output is shorted. With a 52V positive supply, maybe Q1 is turned on which would short the output of U2 to ground. Q1 is turned off by R14. The vaue of R14 was 1.5k for a 35VDC positive supply, then was changed to 1.2k for a 43VDC positive supply. R14 should be about 1k for your 52VDC positive supply to make sure Q1 is off during operation of the circuit.What's my best bet?Get a 30V/4.3A 130VA transformer.Get a much bigger heatsink and mount it on the outside of the case. Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 13, 2006 Report Share Posted September 13, 2006 First i want to know how the voltage in output of U1 gradually increases till D8 turn on?U1 doesn't have a negative supply so its output can go only positive.R5 and R6 provide positive feedback so that the output voltage is double the voltage at pin 2.The output voltage begins a little positive and the positive feedback increases it until the zener diode conducts at 5.6V, making pin 2 also 5.6V and then U1 makes its output double at 11.2V.And my second question is about the current limiter; in fact i read the explanations but i wonder if some body explain more about how it work...U3 is used as a comparator. It compares the voltage across R7 due to load current, with the voltage setting of the current-setting pot.When the voltage across R7 exceeds the voltage from the pot, then the output of U3 goes low which causes D9 to conduct and pull down the voltage at the input of U2. Then the output voltage decreases, reducing the load current until the voltage across R7 equals the voltage at the current-setting pot. Quote Link to comment Share on other sites More sharing options...
roujhan Posted September 14, 2006 Report Share Posted September 14, 2006 Thanks audioguru .But I thought R7 and pot connect to the same pin of U3 and can't compare with each other (?)And what about C8 role here?!Thanks again... :) Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 14, 2006 Report Share Posted September 14, 2006 But I thought R7 and pot connect to the same pin of U3 and can't compare with each other Quote Link to comment Share on other sites More sharing options...
roujhan Posted September 20, 2006 Report Share Posted September 20, 2006 Thanks alot audioguru .But I think I'm right. see, R7 connect to R17 and then P2... and the other pin of opamp connct to pin 4 through R21...please answer and help me!!!Thanks In advance, audioguru . Quote Link to comment Share on other sites More sharing options...
