MonSSter Posted May 13, 2006 Report Share Posted May 13, 2006 i do use 24 transformer.the 6pin on U2 shows ... 0V, and the Q2 shows 34V ... so you think that Q2 is destroyed? Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 13, 2006 Report Share Posted May 13, 2006 If the collector and base of Q2 are reversed then the output of the project would be 33.3V and the output of U2 would normally go low to try correcting it.Q2, Q4 or both might be shorted. Quote Link to comment Share on other sites More sharing options...
MonSSter Posted May 14, 2006 Report Share Posted May 14, 2006 well ... i changed the orientation of the Q2( so that the emitor is pointing towards 8th pin( the base of Q4 ) ) and now the situation is following ... output voltage is 0.5V, u2 is still heating like mad ;), the voltage on Q2 collector is ~34V ...Q4 base volt. = 0,5V collector volt. = 34VQ3 emmiter volt. = 34VU2 output = ~200mVany directions? Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 14, 2006 Report Share Posted May 14, 2006 Its output voltage (emitter of Q4) is 0.5V and also is ithe base of Q4. Therefore Q4 is shorted base to emitter.The output voltage of U2 is less than the output voltage when it should be about 1.4V higher, and it gets very hot. Therefore U2 is destroyed.Q2 might be damaged from being connected wrong, it probably damaged U2. Quote Link to comment Share on other sites More sharing options...
MonSSter Posted May 14, 2006 Report Share Posted May 14, 2006 ok .. will go and replace these componets and then report :) .. thx Quote Link to comment Share on other sites More sharing options...
Tristable Posted May 16, 2006 Report Share Posted May 16, 2006 Hello,it's me again.I've replaced burned output transistor with 2 new ones. I still belive that current regulation is not working, because load isn't reacting on pot 2 changing no mather how, just, like I said before, only drops the voltage down and turns the LED on at max setting.Can you please give me some advices or measuring points to check this out?Or, could it be something else wrong?Please, help me!Thanks, Triple. Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 16, 2006 Report Share Posted May 16, 2006 Hi Triple,I think your project works fine.The current regulator causes the voltage to be reduced until the set amount of current flows in the load. Try a 10 ohms load resistor: 1) 30V/10 ohms= 3.0A.2) If you turn down the current setting then only 20V/10 ohms= 2.0A.3) Turn it down more then only 10V/10 ohms= 1.0A.4) Turn the current setting all the way down and the output voltage should normally be nearly zero. Quote Link to comment Share on other sites More sharing options...
Tristable Posted May 21, 2006 Report Share Posted May 21, 2006 Hi! I think your project works fine.Yes, you're absolutely right! My power supply is working! :DI think the pot should have its wiring reversed so that it gives max current when it is turned to max.Yes, you were right about that too. My apologies that I claimed contrary. What else to say... Everything is working fine, just one thing I don't understand: I have exactly 30,8 VDC and 3,08 ADC at max setting over 10 Ohm resistor, but I have only 100VA transformer. ???And, of course, big big thanks to designer of this circuit, everyone who helped with it's modification, and especialy Mr. Audioguru for doing such a great job. Thank you. Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 21, 2006 Report Share Posted May 21, 2006 My power supply is working!Good! ;DEverything is working fine, just one thing I don't understand: I have exactly 30,8 VDC and 3,08 ADC at max setting over 10 Ohm resistor, but I have only 100VA transformer. Quote Link to comment Share on other sites More sharing options...
Tristable Posted May 21, 2006 Report Share Posted May 21, 2006 Hi!When I buy proper heatsink I will test PS for a longer period and then report. It's robust, it will keep it up. ::)And a question about measuring output current as voltage over R7: wont R7s tolerance and temperature change ruin correct reading? Thanks, Triple Quote Link to comment Share on other sites More sharing options...
spy_id Posted May 21, 2006 Report Share Posted May 21, 2006 Hi audioguru and others,Very much looking forward to building this but want to be 100% sure of the approach from the start. I'm fairly new to electronics though so please excuse the stupid questions... in replacing D1-D4 diodes with a single bridge and Q1/Q2 with TIP31A, Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 21, 2006 Report Share Posted May 21, 2006 replacing D1-D4 diodes with a single bridgeYes. Then it can be bolted to the chassis as its heatsink.don't we need an updated PCB diagram? Not sure Q2's TO220 style case and heatsink would fit well on the original board design. Unfortunately I already have the etched board!The same pcb is fine. A few larger resistors will need to be spaced above the board. Q1 will need its pins bent around. Q2 can be bolted to the heatsink and won't need an insulatopr and the Q4's are also without insulators. Then insulate the heatsink from the chassis. Quote Link to comment Share on other sites More sharing options...
glockshotz Posted May 26, 2006 Report Share Posted May 26, 2006 I am almost finish designing my power supply, However I was only able to get a transformer with a rating 24vdc with 100VA. So my transformer will be supplying 4A current will this work? Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 26, 2006 Report Share Posted May 26, 2006 A 24V transformer has a peak voltage of 34V. The rectifier bridge will drop about 2V at full output. The two darlington-connected output transistors, R15, R7 and U2 will drop about 8V at full output leaving about 24VDC for max output.The transformer's peak voltage of 34V will have an average current of 4A which is 136VA. Your transformer is way overloaded when the project has a 4A output.100VA/34V= 2.94ADC. When the load draws slightly less than 3A then the transformer will be operating at an average of 100VA.Add them up:24V/3A for the load. P= 72W.8V/3A for the parts. P= 24W.2V/3A for the rectifiers. P= 6W.Total power= 102W. Quote Link to comment Share on other sites More sharing options...
muffits Posted May 29, 2006 Report Share Posted May 29, 2006 At first I'm quite newbie in electronics and me and my firend decided to make our course project about this power supply. And there is needed some analysis and calculations. So in schematic is C4, R8 and R9 ... why are these needed? I understand why C5 is nessesery, but isn't better to use a ceramic cap. (we use mod list - [email protected])? And there is that ripple... How I can make somekind of calculations about ripple in U2 output (pin 6.) and how about calculations about ripple smoothing by Q2 and Q4 (we going to use two 2N3055). And how about C9? (I undestand that, it puts U2 working also like integrator). C6 is understandable in high frequencieis...can anyone help us about these problems ? :-) Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 30, 2006 Report Share Posted May 30, 2006 At first I'm quite newbie in electronics and me and my firend decided to make our course project about this power supply.Hi Muffits,Welcome to our forum. ;DSo in schematic is C4, R8 and R9 ... why are these needed?R8 and C4 are a filter to remove high frequency noise from the D8 reference voltage circuit. R9 isolates C4 so that D9 can reduce the voltage of the project quickly when current regulation needs it to be reduced.I understand why C5 is nessesery, but isn't better to use a ceramic cap?It doesn't matter because the opamps don't operate at radio frequencies when a ceramic cap would be necessary.And there is that ripple... How I can make somekind of calculations about ripple in U2 output (pin 6.) and how about calculations about ripple smoothing by Q2 and Q4 (we going to use two 2N3055).U2, Q2 and Q4's amplify the reference voltage output of U1. U1 has hardly any ripple because it is the current source for D8 and buffers D8 from the unregulated supply.And how about C9? (I undestand that, it puts U2 working also like integrator). C6 is understandable in high frequencieis...C9 reduces the high frequency gain of U2 so that it doesn't oscillate when Q2 and Q4 are added in its negative feedback loop. Quote Link to comment Share on other sites More sharing options...
muffits Posted May 30, 2006 Report Share Posted May 30, 2006 A silly question: in wich frequency is low pass filter (R8, R9 and C4) calculated on? I mean does it block from 100Hz to ...? Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 30, 2006 Report Share Posted May 30, 2006 A silly question: in wich frequency is low pass filter (R8, R9 and C4) calculated on? I mean does it block from 100Hz to ...?The resistor R8 has part of P1 in series with it so the total resistance is about 32k ohms. Therefore the cutoff frequency of 32k ohms with C4 is about 50Hz. Quote Link to comment Share on other sites More sharing options...
muffits Posted June 3, 2006 Report Share Posted June 3, 2006 A small thing that I've noticed... I simulated C4, R8 and R9 and only R8 and C4... and thing is that with R9 isn't it 3 order LPF (as without it it's 2 order LPF)? The thing is with with R9 it cut's harder frequencies, then without R9..... it's just a remark...btw at 100Hz it drops ripple voltage something like 30 times...c :-)And a question.... I understand why C6 and C9 are neended, but can anyone explain they workin principals.... Sry about all my silly questions, but I can't get rest, unless I know enough :-DPS. If anyone intrested, then this is how should U3 output voltage look like, then it is working. (the red one is u3 output) Quote Link to comment Share on other sites More sharing options...
muffits Posted June 3, 2006 Report Share Posted June 3, 2006 About C4, R8 and R9 forget it.... my bad, R9 only takes down a bit amplitude of ripple voltage at low frequencies (something like to 10Hz). So I still don't understand R9 fuction.... I remeber that audioguru said that it isolates D9... does it mean that for D9 R9 seems to be source? Quote Link to comment Share on other sites More sharing options...
audioguru Posted June 4, 2006 Report Share Posted June 4, 2006 The input of the opamp U2 is megohms so R9 doesn't affect how it works, until the current regulator U3 needs to quickly reduce the voltage at the input of U2. Then the resistance of R9 isolates C4 from the input of U2 so that D9 can quickly reduce the voltage at the input of U2 without waiting for the filter C4 to discharge.This project is regulated and shouldn't have ripple. If R4 is the original too high value of 4.7k instead of 1k, and D8 is a high current zener diode instead of a 5mA one, or if C1 is the original too small 3300uF instead of 12,000uF then the output will have ripple. Quote Link to comment Share on other sites More sharing options...
MonSSter Posted June 4, 2006 Report Share Posted June 4, 2006 helow! it's me again :) .. well i replace the Q2 and the u2(new one is still heating like mad) and now the output voltage is ~0.4V .. the voltage in q4 E,C and B is 32V+ ... so what is wrong now? Quote Link to comment Share on other sites More sharing options...
audioguru Posted June 4, 2006 Report Share Posted June 4, 2006 i replace the Q2 and the u2(new one is still heating like mad) and now the output voltage is ~0.4V .. the voltage in q4 E,C and B is 32V+ ... so what is wrong now?Q4 is shorted and might have destroyed the new U2 and Q2.Remove R15 and get Q2 and Q4 working properly first. As a test, connect two 10k resistors to the base of Q2. Connect one resistor to +34V and the other resistor to the output's 0V. Without a load, the output voltage should be about +15.7V. Without R15, U2 should be cool. Quote Link to comment Share on other sites More sharing options...
MonSSter Posted June 4, 2006 Report Share Posted June 4, 2006 hmm .. I replaced q4 and u2(q2 looks ok)disconeted the r15 but nothing happend... output was i bit higer that's all ... so the thing still doesn't work :D ... any new directions(maybe you draw me the solution :)). Tnxeemmm ... q4 C = 34V, E = 0,5V B = 0,5V Quote Link to comment Share on other sites More sharing options...
audioguru Posted June 4, 2006 Report Share Posted June 4, 2006 Hi MonSSter,In your reply #931 all 3 terminals of Q4 were at +32V and the output of U2 was at 0.4V. So I thought that Q4 was shorted.Now with R15 disconnected the base and emitter of Q4 dropped to +0.5V which is normal.The output voltage of U2 is high which is normal without R15.Is U2 still hot?Which part number is U2? Quote Link to comment Share on other sites More sharing options...
