Jump to content
Electronics-Lab.com Community
Posted
    I recently found out that if you have resistors of the same value wired in paralell, the resistance is lower than one of the resistors in the paralell. For example, if you have 2 resistors that are 50 ohms each, wire them in paralell and their resistance is 25 ohms each. I don't understand how having resistors in paralell will lower resistance. Can someone tell me why the resistance divides by 2 when you add 2 resistors of the same value?
Thanks a ton.
Posted
Any number of resistors of the same value in parallel is equal to the resistor value divided by the number of resistors, it's not just limited too 2... i.e. 10, 100ohm resisistors in parallel is 100/10=10ohms... it's one of those things that works out that way given certain conditions.
The equation for any values in parallel is Rval= 1/ (1/R1+1/R2...1/Rn). I suppose you could algebraically manipulate the equation to get Rval=R1/n when R1=R2=R3... if you wanted to really prove it to yourself.
Guest nanop
Posted
a helpful formula to know when u are only finding the resistence of only 2 resistors in parallel is
Rt= (R1*R2)/(R1+R2)
Posted
I believe you are confused because you stated that two 50 Ohm resistors in parallel causes them to become 25 Ohms each. This is incorrect. They stay 50 Ohms each, but the resistance of the whole becomes 25 Ohms.
A single water pipe has a certain resistance to flow, but two such pipes permit twice as much flow. The same principle applies with electrical resistance. Two identical parallel paths provide half the total resistance that one would provide.
Bugger. Sorry Zeppelin.
Guest nanop
Posted
Can't believe something in basic electronics got so much attention, confusion.  :)
  • 3 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
