Jump to content
Electronics-Lab.com Community
12v power supply?
Ian H
Find yourself a +- 220v/12v transformer capable of handling 200ma, a 1a bridge rectifier, and a 1000mfd 25v electrolytic capasitor and a piece of veroboard. Over a switch and a fuse take the 220v to the transformer with the rectifier in serie and the cap in parrallel you should get a bit more than 12v to power your LED's. But I must warn you The mains supply of 220 volt is very lethal. If you know nothing about power electronics leave it alone and rather go and buy yourself a comercial power supply that is capable of handling the power of LED's. The current of smal led's is a couple of mA and bigger ones do not need a lot more. Enjoy!
Link to comment
Share on other sites
This solution will supply about 17V at low load! This could damage LED
Link to comment
would this be ok:
http://cgi.ebay.co.uk/2-pack-of-AA-Battery-holder-8xAA-12v-with-PP3-clip_W0QQitemZ280054793903QQihZ018QQcategoryZ7285QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
?? some one above mentioned using 8AA batteries for a 12v supply? would it just be a case of cliping the +ive terminal to +ive wire/led leg and -ive terminal to -ive wire/led leg??
Link to comment
would this be ok:
It is perfect for holding 8 AA battery cells to make 12V. But a charged and charging car battery is 13.8V.
Yes.
Link to comment
Ian,
What I would do is get several old phone chargers. Lets say you have two phone chargers that puts out 6Vdc each. Take the positive from one and the negative from the other and check the remaining leads, which should equal 12Vdc. The power source doesnt have to be strickly old phone chargers, perhaps an old remote control car batter charger, etc. Oh yeah be sure to get a multimeter to check voltages!
Link to comment
any chance of a quick diagram ante? i think i know what you mean but I'm probably wrong!
Ian,
im having trouble under standing batteries, last thing i want at the moment is to be playing around with mains electric  :o :o
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
