Jump to content
Electronics-Lab.com Community
Posted
Hellow,
I build the following pi filter to match 100 ohm source to 1000 ohm load, I did the calculations based on RF Circuit Design Book
As u can see at the center freq fc = 30MHz & Q=15 I had 3.771dB, I was surprised by where this value? this is amplification!!!!
The second question is: If i want to match 1000 ohm source to 100 ohm load, Simply replace the capacitors, one must place the other, when i did so and simulate i had the following:
[img width=680 height=478]
Look!! -9.8dB at the center freq.
can you please comment, how to match big source to small load without that bad attenuation
thanks alot
Posted
I'm surpised at the results. I know that mismatching impedances can cause standing waves, and it may depend on where you probe on the transmission line. But I think there would still be enough signal loss, and it would seem hard to get that good of a measurement to make a comparison.
Posted
This is a "second order" circuit. You took a bode plot over a frequency range. Things are going to change over frequency. Have you solved the differential equation for this circuit to find the poles and zeros? It's also what is called a "passive circuit"... so, unless you hit a resonant frequency (as AG pointed out) in your sweep, this thing can only attenuate.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
