Jump to content
Electronics-Lab.com Community
opamp roll-off
Kevin Weddle
I was thinking the loss was due to voltage loss at the base emitter junctions because of capacitance. And that the slew rate specification guarantees low signal distortion.
The base-collector capacitance reduces the gain of a transistor much more than the base-emitter capacitance because base-collector capacitance (Miller capacitance) is negative feedback.
The loss of output at high frequencies is because the output cannot slew fast enough. Instead of following the waveform at the input, the output has ramps. The ramps are slow so the output level at high frequencies is reduced.
The slew rate limit causes every high frequency waveform to become triangle waves. Then the distortion is extremely high.
Link to comment
Share on other sites
Low frequency opamps like the LM358 dual and LM324 quad use low power supply current which causes poor performance at higher frequencies. Their low current also causes 3% crossover distortion.
I have never used a high frequency opamp. Most ordinary audio opamps perform very well up to 100kHz.
Link to comment
I'll post what I did before but deleted.
Here's how the roll-off limits the high frequency gain and how a reduction in closed loop gain and increased negative feedback, increases the bandwidth.
Going back to the graph posted by audioguru.
http://www.electronics-lab.com/forum/index.php?topic=19813.0
If the gain is set to 1000, the 6dB bandwith will be 1kHz.
If the gain is reduced to 100, the 6dB bandwidth will be increased to 10kHz.
Of course the bandwidth of actual op-amp remains the same, it's the bandwidth of the circuit which increase as more negative feedback is applied.
The obviously doesn't make any difference to the slew rate which is a limitation of the op-amp's ability to change from one voltage to another quickly so the 741 is still limited to <8kHz in most applications.
Do low frequency op-amps have any advantages?
Lower frequency op-amps are more stable than high frequency op-amps and are cheaper too.
Link to comment
  • 4 weeks later...
Low frequency opamps are more suitable for low frequencies than high frequency opamps? I'm not so sure because opamps have a bandwidth that extends to 0Hz. A high frequency opamp would maybe incorporate newer technology bipolar transistors, and maybe extra transistor amplifier stages to make up for loss.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
