HellasTechn
- Apr 14, 2013
- 1,579
- Joined
- Apr 14, 2013
- Messages
- 1,579
My question has to do wth the flyback diode in the below described circuit.
I have two relays in serries (6V coil each) that are connected to a 12V source and controlled via a logic gate mosfet. I know that a flyback diode has to be placed as close th the relay's coil as close as possible but the relays are about 3 inches appart from each other on the PCB.
What would be the best place to put the flyback diode to protect the mosfet ?
How would you connect the flyback diode if you had to in the circuit shown below ?
the circuit diagram is attached below.
Thank you so much.
Thank you so much.
