Sallen Key Low Pass Filter, bandpass filter
Maglatron
Jul 12, 2023
2,025
So this question goes out to Bertus because it's his wonderful suggestion!!
Hello,
That is a very complicated detector.
A simple diode with a capacitor to ref might even do the trick.
Bertus
bertus
3,868
Hello,
Did you see post # 389?
I shows the effect of the RC timing.
100 nF and 1 megohm will have a full decay of about .5 sec.( 5 x rc time)
Bertus
Maglatron
Jul 12, 2023
2,025
red is before the diode and after the signal generator and green is between the cap and ground!
bertus
3,868
Hello,
What happens in the envelope?
What kind of diode do you use?
A shottky diode has a smaller voltage drop.
Bertus
Maglatron
Jul 12, 2023
2,025
Your first question, I don't know I don't see anywhere else to put the probe apart from after the diode and before the cap and resistor, which yields a flatline at zero volts, secondly just the standard one from the from the button at the top of the LTSpice program I'll put in a shottky now
bertus
3,868
Hello,
Can you post the .asc file from your simulation?
Also post the .wav file (rename the file to .txt before posting)
Bertus
Maglatron
Jul 12, 2023
2,025
before the diode and after the signal = red
after diode and before cap and resistor = green
after capacitor = turquoise
signal before diode (red) after cap (turquoise)1702072109746.png1702070748668.png
  • 45Hz.asc
  • 45Hz.txt
bertus
3,868
Hello,
You used a resistor of 1 mili ohms in stead of 1 mega ohms.
Try the attached .asc and see what happens.
Bertus
  • 45Hz.asc
Maglatron
Jul 12, 2023
2,025
aaaaaaahhhh ok
so now I'm going to do 16000Hz and see if it's still does the enveloping effect!
Is that a good outcome ie is it good enough to use
Maglatron
Jul 12, 2023
2,025
I'm having major trouble going 16 bands logarithmically from 45Hz to 6000hz any help??
Maglatron
Jul 12, 2023
2,025
I'm going to build two, one that have the 45Hz to 16kHz because I have the parts now, and one 45Hz to 6000Hz need to space correctly though normally I use chatgpt for the spacings but its just spitting out BS at the moment
Maglatron
Jul 12, 2023
2,025
Hello, do you know how to get the spacings on a logarithmic scale from 45Hz to 6kHz please for 16 bands??
also I'm having a small problem of this
Maglatron
Jul 12, 2023
2,025
Does hz go on the x or y axis here? I'm pretty stuck does base 2 have anything to do with the scale?
