Not being funny but then why can't you draw a current off of a magnet that is not moving in comparrison to a coil or vice versa surley the action of moving the penny towards the magnet is which induces the eddies when the penny is not moving then no eddies are set up in the penny, it's the MOVING that creates eddies! and the pennies ar stuck to the magnet and therfoe are not moving in comparison to the magnetsAll magnetic fields are created by electrical charge meaning even a static magnetic field a in a permanent magnet . The charges are moving because the electrons are orbiting the nuclei .
more accurate description would be discreet energy levels within an atomic system, putting a penny close to a permanent magnet creates the system and because the penny contains copper which is highly conductive it allows the formation of Eddy Currents which is the wave like nature of subatomic particle
That is not a fact and your theory sucks.this fact is what I'm basing my theory on and I thought thats how it worked before I found evidence that I wasn't too far off in my idea
The quote below was incorrect my observation was wrong.you are picking and choosing information
That conforms to your thought process
I admit it.You are not listening.
anyway you are plain wrong to induce a current you need to either create a moving magnetic field by electromagnet or move a permanent magnt in relation the coil either way for a current to form you need moving magnetic flux field, otherwise you could draw a current off of the magnet in situ next to a coil this does not happen and if you don't have anything constructive to say do say anything at all!That is not a fact and your theory sucks.
Modern English pennies are copper plated steel. That is a fact and one that you have chosen not to incorporate in your theory that sucks.
Electrons are moving so you need not physically move anything Eddy currents are formed in the non-ferrous highly conductive material the copper plating surrounding the steel.
I admit it.
You have selective hearing!
Dirac equations is particularly useful in describing the behavior of electrons in the presence of electromagnetic fields including magnetic fields and highly conductive non-ferrous materials within magnetic fields.
I think it does. If the coin is between the magnet and the coil surely it will experience the vector sum of the coil-generated field and the magnet's field? That sum is changing because the coil-generated field is changing. The change in the sum won't be much though, if the magnet's field is a lot stronger than the coil's field. Also, the coil's field presumably extends into the magnet, rather than stopping abruptly at the magnet face, so would affect the magnet's net internal field slightly.But drawing current does not make the flux change in the magnet and by extension, the coin.
It's also possible by varying the strength of the magnetic field with no movement involved.to induce a current you need to either create a moving magnetic field by electromagnet or move a permanent magnt in relation the coil
and I would do this by electromagnetism, varying a current through a coilIt's also possible by varying the strength of the magnetic field with no movement involved.
did you read my post about the magnets themselvesI think it does. If the coin is between the magnet and the coil surely it will experience the vector sum of the coil-generated field and the magnet's field? That sum is changing because the coil-generated field is changing. The change in the sum won't be much though, if the magnet's field is a lot stronger than the coil's field. Also, the coil's field presumably extends into the magnet, rather than stopping abruptly at the magnet face, so would affect the magnet's net internal field slightly.
would this be correct thinking?? I think the eddies must be present in both the coin and the magnets if the field of the coils affects the coin it must affect the magnets too?in any case the magnet its self is made of ferromagnetic material by nature of how magnets are made, so then you should say that there are eddies present in the magnets when they are generating power
I agree. Those eddies would create additional minor modifications to the magnetic fields. Everything seems to interact.I think the eddies must be present in both the coin and the magnets
Then English isn’t one of themI can only speak four languages fluently; what does chuffed mean in English?
yeah thanks for that Mr Martaine2005Then English isn’t one of them
Chuffed = Really pleased, so happy, over the moon etc.
